Brake Help
Brake Help
I have just installed Powerstop Crossdrilled and slotted rotors all the way around and Hawk HPS pad and ive notice that whenever I stop slow it make an annoying whine or squeking noise....It seriously pisses me off....I spent some good money on this set up and I personally think i should change out the pads. IF i stop fast though it doesnt make the sound but lemme know so i can get it fixed thanks a ton everyone!!!
Cross drilled or slotted rotors can make a "whirring" noise when you stop. That's due to the holes and something you can't help. If it's a squeaking, squealing noise, you can try the anti squeak compound on the back of the pads, or put a very light layer of disc brake caliper lube on the back of the pads (where they touch the caliper). This will prevent the metal on metal grinding action that causes the squeaking sound. Just don't go overboard, we don't want to grease to melt and wind up on the rotors. A light layer is perfect.
Copy & Paste Moderator
trackbird covered it, but I still have a question for you.
Did you follow Hawk's break-in procedure for their HPS pads?
Following the proper break-in will give you better braking and may lessen the squeak.
