Generation III Internal Engine - whose all running 6quarts of oil
View Full Version : whose all running 6quarts of oil
SLP4CamaroSS
04-03-2007, 02:36 AM
whose all running 6 quarts of oil on a regular length oil filter. any problems?
DaddySS
04-03-2007, 03:24 AM
Half a quart overfill should not cause major problems, generally you don't want to overfill because of increased windage, foaming, etc. of the oil but good oil and only 1/2 quart should make it less of a concern here.
SStingray
04-03-2007, 04:36 AM
I've been running 6 quarts in my LS1 for over 5 years and 1/2 quart over in many cars over the last 25 years. No problems.
cowboysfan
04-03-2007, 04:56 AM
just wondering what benefit would 6qt or 1/2 qt more get you? I usually run at 1/2 mark on dip stick to prevent windage/foaming.
slow trap
04-03-2007, 06:19 AM
since most everyone's lsx engines causes oil to dissapear i wouldn't think there would be anything wrong with it being half a quart high,especially since soon as you start it up and take off and it starts sloshing and roping it is a quart or more lower.
Randy WS6
04-03-2007, 07:14 AM
I use the K&N oil filter #2006 (long Filter) 6 qts. puts me on the full mark.
BlackScreaminMachine
04-03-2007, 07:22 AM
I fill the filter and put 5.3 quarts in, never an issue. The only time to worry is iff you put 10-15 quarts in it, its happended at dealerships and it locks the motor. At worst a lil oil on the crank could take a few hp off of the table, 1/2 quart shouldn't do that.
Camaro99SS
04-03-2007, 08:59 AM
Just run the longer filter. For K@N's, it's par # 2006. No reason to run high when you can run a bigger oil filter with no clearance issues.
Jason
SSpdDmon
04-03-2007, 09:03 AM
I run 5.75 each oil change. I fill the filter up before install, which is usually .25 for the stock filter and I put 5.5 in the head.
Steve Burger
04-03-2007, 11:06 AM
6 and the long filter
lt1formula2000
04-03-2007, 12:25 PM
i run 6 and the regular filter with no problems
Griswold
04-03-2007, 01:10 PM
6 and the regular filter since I purchased the car in January 2001
01Z0H6
04-03-2007, 01:42 PM
6, reg filter...
4yall2nv
04-03-2007, 02:36 PM
i run 5 quarts and a bottle of lucas! reg filter
Grimes
04-03-2007, 04:44 PM
I've run 7 quarts before auto-x events, then kept it in there for a while. no problems at all.
01WS6/tamu
04-03-2007, 05:11 PM
6 and a long filter
MCBRIZ28
04-03-2007, 05:54 PM
6 and regular filter also
RocketCutlass
04-03-2007, 06:25 PM
me too, i've heard of some people using just 5 quarts with no problem, way back when, drag racers would actually run like 3 quarts so the oil wouldnt hit the crank tryin to get every horse they could out of the motor. the level of oil in the pan rises like a 1/4 inch with the extra half quart, maybe less.
BriancWS6
04-03-2007, 06:45 PM
6 qts with the longer filter.
NHRAMAN
04-03-2007, 06:59 PM
So do I .......... :judge:..5-1/2 Quarts all together. [I use a large bottle and just put in a 1/2 quart or so of LUCAS OIL TREATMENT.][on top of my usual 10W40 Castrol]
BLKWS.6
04-03-2007, 07:30 PM
6 qts and a regular filter. Dunno about you guys running only 5 qts to prevent windage, last I checked 7qts and a regular filter still wont hit the crank...5 qts and a corner and high rpm MIGHT spin a bearing though...
Brads LS1 02Z
04-03-2007, 07:46 PM
5.5 qts with moble one filter
Rob
04-03-2007, 11:59 PM
All GTO's get 6.5 to fill it. Funny thing is the owner's manual says to add a quart when racing and then drain that quart back out when finished. So that's 7.5 quarts!
WADDISME
04-04-2007, 08:57 AM
I run 6 plus long filter, then added 1 qt for a/x and left it in. No problems yet.
WhosNXT
04-04-2007, 09:31 AM
6 and a long filter, no probs
ILLWS6
04-04-2007, 12:12 PM
I don't get it. I use a regular sized filter and my car has always taken 6 quarts to reach the full mark.
GR33N GoblinM6
04-04-2007, 01:14 PM
7 quarts here.. because i have an oil cooler with swallows 1 quart...
