Ok seriously how big to go for engine size?
Old 04-03-2007, 01:31 PM
MY99TAWS6's Avatar
Default Ok seriously how big to go for engine size?
I have pretty much decided to go iron block but not sure how big to go. Planning on APS twins now.So really is a 427 going to be worth it over a 370? How much faster spool ,how much more torque. How much better off boost response?
Going with patriot stage 3 lq9 heads, have lingenfelter gt7 cam and fast 90 / NW90.
Planning on staying with my six speed for now and likey something like 9 inch ford with 3.50 or so gears. It is worth the extra grand and half or so to
go up to a 427?
Is it worth going to say lunati or calllies crank over eagle cranks?Any eagle crank failure and at what hp level.I doubt would ever go much past 1000engine hp .Car is pretty much street car. Heck much past 500 rwhp is pretty hard to hook up even on my nittos I would think.I do like good off boost power though thats why thinking going to 427.And would think it would help spool the turbos up quicker.
Are the compstar rods good enough for this or should I spend extra for lunati pro mod rods think its only a 100 and half or so?
Old 04-03-2007, 01:36 PM
Rickys S/C Z28's Avatar
man im a newbe but i would go bigger if i could, because like you i want more off boost power plus, lets face it its cool as a **** to say you have a 427.....with boost!!
Old 04-03-2007, 01:40 PM
MY99TAWS6's Avatar
Yeah no doubt the cool factor of the number 427 is magical and of course they use it to the hilt in the new z06. And would think the 427 would be a torque monster off boost .Plus you do lose compression with the turbo thing so nice to gain some torque back I would think. Wonder what is about right for compression..9 to 1..9.5 to 1 ,8.5 to 1..I run like 8.8 in my turbo talon and that seems ok.
Old 04-03-2007, 02:13 PM
smokinHawk's Avatar
unless you can get T4 turbos with the APS i would stay with 370 cubes, the turbos will make your power and be more in the efficency range, if you go with a 427, torque will be to much and you could choke the engine with the turbos.
Old 04-04-2007, 06:58 AM
chuntington101's Avatar
like smokinHawk said,the turbos are your limiting factor. from what i have heard 370 is a nice engine size for the APS stuff. although they have proved to be good upto 402.
if you still want more low end torque then might be worth taking a look at a small shot of N2O low down to help spool the turbos/provide some cooling. or you could go for an anti-lag system
thanks Chris.
Old 04-04-2007, 09:41 AM
MY99TAWS6's Avatar
My fast intake is set up for direct port so was mabye going to put system on even if it was mostly for show still of course small shots help spool up .A 370 or 402 should still be plenty torquey I would think even with lower compression . So again what do most guys set up for compression .8.5 seems low would think 9 to 9.5 would be bit better.
Old 04-04-2007, 10:04 AM
LS1TECH Sponsor
DrTurbo's Avatar
8.5cr 370.......that's all you'll need.
Old 04-04-2007, 10:13 AM
SSilverSSurfer's Avatar
i hear the FAST intakes seperate under boost
Old 04-04-2007, 05:35 PM
Darren P's Avatar
I know that they keep saying that It will work but till I see it I just dont think that I would want to use the APS kit on a engine larger than the 370
I have a 403 and I think that it would be to large for this kit
Old 04-04-2007, 05:44 PM
theres no such thing as TOO LARGE,
Old 04-04-2007, 05:46 PM
Darren P's Avatar
there is if you are running a turbo setup with to small of a turbo
Old 04-04-2007, 05:47 PM
Piersin's Avatar
APS is coming out with a Z06 kit
Old 04-05-2007, 12:56 AM
peter@aps's Avatar
The APS turbos wil be plenty big enough for a 427 cube engine.
Peter
Old 04-05-2007, 12:59 AM
peter@aps's Avatar
Wrong...............the APS turbos will flow plenty on a 402 cube engine..............each turbo has 50 lbs per minute mass air flow at around 16 to 18 PSI. That's sufficient mass air flow for around 1000 HP.
Peter
Old 04-05-2007, 01:25 AM
well ther you go bigger is better(just dont let my wife find out) hahahahah
Old 04-05-2007, 01:49 AM
Peter, i hear the Z06 turbos will be bigger, to tkae advantage of the 427. is there anyway of retro fitting these bigger units to other APS kits??? just thinging if you could enginer this it could be a nice little profit maker for you guys, and let the guy with the smaller APS turbo upgrade to make more power!
thanks Chris.
Old 04-05-2007, 02:16 AM
dacajun's Avatar
It being a street car I would say the 370 for a few good reasons. #1 cost, a good 6.0 block along with the stock crank and a good set of aftermarket rods and pistons. To get that magic 427 cid your going to invest some serious coins in doing so. That's money that can be used elsewhere. As smokingHawk mentioned the turbos will make your power. #2 Traction, more cubes and as you already know traction will be a huge issue. Now if this would be an all out drag car by all means all the cubic inches your budget will allow along the right turbos and a good engine management system.
Good luck,
Dave
Old 04-05-2007, 07:28 AM
FastKat's Avatar
What are your power and performance goals? What will the car be used for? How much cash do you want to spend? Those are the questions you need to figure out first. Then you can build to your chosen application.
Old 04-05-2007, 04:41 PM
Darren P's Avatar
Peter
do you have a efficiency map or an Island map for one of these
thanks
Darren P
Old 04-05-2007, 06:18 PM
LS1TECH Sponsor
DrTurbo's Avatar
Compressor map is only half the equation. The turbine side is the problem not the compressor side. You will need a pretty fast turbine velocity to compress the air to 16psi on a 402. That will mean your exhaust pressure will rise fairly quickly.
Quick Reply: Ok seriously how big to go for engine size?
