Gears & Axles - 3.42's any louder stock for stock than 3.23's?
eagleknight97
04-03-2007, 02:04 PM
Would there be any noticeable difference in noise for the two, if they are same manufacturer and set up the same?
No, you won't hear a difference between the two. Bob
eagleknight97
04-03-2007, 03:50 PM
If I just wanted to have the rear rebuilt, this is the kit that would get me there right?
Thunder Racing Kit (http://www.thunderracing.com/catalog/?action=vshop&vid=4&pcid=68)
Are Motive gears good stock replacements?
00BlueTA
04-05-2007, 11:36 PM
If your going to have the rearend rebuilt you may want to go a little steeper depending on your setup. The only gears I know to have a common noise problem is the 4.10. My friend in his z28 used the motive gears and had no problems, and I am pritty sure they are stronger than the stockers.
eagleknight97
04-05-2007, 11:44 PM
Noticeably steeper gears wouldnt work for me really, cuz its a daily driver, no stip duty at all. And the rear is getting re-done because its whining right now and has 125k on it, I figure a general overhaul would be good for it.
Revelation Z28
04-05-2007, 11:58 PM
my 4.10s didnt make noise until about 2000 miles after i had them. then they are whining in 5th-6th on the gas.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
