I need rearend torque specs!
I need the torque specs for the two side bearings on the carrier, the pre load for the pinion(should be in inch-punds), and i also need to know what the backlash is supposed to be!!
HELP ME PLEASE I need to get my car running today!!
According to Yukon installation instructions:
http://www.ringpinion.com/Content/Ho...lation_Kit.pdf
Pinion bearing preload: 12-15 in-lb for new bearings, and 6-7 in-lb for used bearings.
Main bearings caps: 60 ft-lb
Backlash: .006-.010"
These are for a 7.5" 10 bolt rear end.
