Have you heard about the new Scoggin Dickey Big Bull LS Motors 413,427,440 cid?
Old 04-04-2007, 12:17 AM
Chicago Crew UnderBoss's Avatar
Default Have you heard about the new Scoggin Dickey Big Bull LS Motors 413,427,440 cid?
Just got my newest edition of GM High Tech Performance today and see that Scoggin Dickey has released their new LS2/L92/LS7 "Big Bull" short blocks.
Man these bad boys look tempting at these prices and what do you guys think about this which I will quote from the magazine all utilzing the new SDPC/CALLIES 4.1 crank. It is my preference to use a 4.00 crank in a big cubes LS series motor but I would think these bad boys would be reliable in a full max effort N/A application that I am looking to build with Trick Flow 225 heads and a nice aggressive street/strip cam making around 11:5 to 1 compression.
HERE YOU GO and let's get your feedback as this is exciting ****:
LS2 block, 4.005 bore, 4.1 stroke crank, 413 cid for $4,569.00
L92 block, 4.068 bore, 4.1 stroke crank, 427 cid for $4,929.00
LS7block, 4.125, 4.1 stroke crank, 440 cid for $6,289.00
"All of the above big bull LS engine short block by SDPC features the new SDPC/CALLIES 4.100 stroke crank, manley forged pistons, scat H-Beam Rods, and a new GM alum Block.
Man this **** is tempting but a new 4.1 crank makes me a little leary as I have had a new Callies 4.125 crank several years ago fail on me and have SWORN I would never go with an ls series motor that was not a simple 4.00 fast reving, battle tested crank, but I am sure that could be offered at these same type of prices (and probably lower) by SDPC, but of course that will not the cubes set forth above down a bit.
What do you guys think? Man, this **** is getting really exciting!
At thes prices one could almost afford to put on a ported LS7 intake and CNC LS7 heads onto this 440 LS7 "big bull" LS7 motor, which should make close to around 575 to 590 rwhp!
Old 04-04-2007, 12:23 AM
prplhaz's Avatar
I'm confident that these fine folks at both SDPC and Callies have done their homework, one of these fine shortblocks will be in my "man-cave" shortly!
Old 04-04-2007, 08:32 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
It's SCOGGIN-DICKEY And we, as well as Callies, have done our homework on these crankshafts and are very confident in the setup. There was actually a thread a couple weeks ago where some other big name builders agreed that it's not the crank that gets you into issues, it's the ring set-up. We've addressed those issues and have not seen any oil consumption issues to speak of with these engines.
Feel free to give me a call if I can help answer any questions about your setups!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-04-2007, 09:18 AM
Matt, you may be hearing from me really soon! I Love the looks of that 440 cid LS7 Motor!
Old 04-04-2007, 09:21 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Title fixed, no more SCROGGIN.
Old 04-04-2007, 09:30 AM
Haha, thanks Tony!!
__________________
Old 04-04-2007, 11:05 AM
DanZ28's Avatar
What's the advantages (besides adding CI) and disadvantages to using a 4.1" crank?
Dan
Old 04-04-2007, 11:42 AM
SideStep's Avatar
Dan
Well... there was some talk about the 4.1 being bad for oil use and/or engine longevity. I have not seen (or read) proof Pro or Con...
Old 04-04-2007, 02:12 PM
TheLS1Kid's Avatar
^^ Wish i had the coin for that baby.
Old 04-04-2007, 04:48 PM
Beast96Z's Avatar
Dan
More cubes equals more power. Plain and simple. There USED to be alot of problems with oil consumption in the long stroke motors due to insufficent piston design and support, but these days, it isn't really a problem unless you have a builder that's been living under a rock.
Old 04-04-2007, 07:15 PM
DanZ28's Avatar
What do you lose with the bigger stroke, RPM? I ask this because I look at some short stroke setups, for example LS1joe's, he is putting down 650 whp with a 385, mainly because he can spin the **** out of it and it just keeps making power, would the same motor with a 4.1" stroke accomplish this in the same way an make more power? Or is it that just because a 440" has more CI than the 385 it will make more power everywhere plain and simple?
Old 04-04-2007, 08:42 PM
03 BUSA's Avatar
More than just spinning it real high to get a high peak number, you want the torque curve, that is what the large bore will get you. Who spins their motor to 8k on a regular basis? I would rather have peak numbers around 6500 but a nice flat torque curve through the whole powerband.
Old 04-04-2007, 11:27 PM
Hmmm, I sell my stock LS6 and ECS D1SC blower kit I would have the scratch for this! I am thinking about going with this set-up along with some ported L92 heads (better yet TRICK FLOW 225s) which should make very good power and STUPID TORQUE, with a nice agressive street/strip cam!
Old 04-05-2007, 09:55 AM
HotRodV6's Avatar
ive been away for awhile, and i too got my copy of GMHTP in the mail the other day and seen the ad for the big bull engines and was drooling over the prices.
But i thought the talk awhile ago was that the L92 or LS2 block cylinders werent long enough to support the 4.100 stroke??
Was that addressed with just a shorter piston and or Con rod?
Also on the L92 427, what would be a safe max rpm to spin that up to, and with some ported L92 heads and L76 intake/90mm TB and somewhere around a 235/240@.050 .600 lift cam what kind of power do you think it could put to the wheels???
Old 04-05-2007, 10:04 AM
Stang's Bane's Avatar
Tosto spins his 4.1 stroke 421 to 8K+ every race..
Old 04-05-2007, 12:25 PM
DanZ28's Avatar
Having a track only car, I spin mine to 7400 now, so I don't care about the Tq down low (personally), I'm never there. Did you mean large stroke for your nice flat Tq or large bore? I am just wondering if you can still spin the 4.1" pretty high, or would it be better to go bigger bore, shorter stroke?
Dan
Old 04-05-2007, 12:51 PM
Dan
Bigger bore with shorter stroke will always make for a faster revving motor that can be spun higher than a smaller bore longer stroke motor.
Old 04-05-2007, 01:00 PM
The only good reason to run less stroke is if you have a displacement limit. I am almost certain the reason Joe(t56) went with the size he did is because of the race class he is in.
NO REPLACEMENT FOR DISPLACEMENT!!
Old 04-05-2007, 08:12 PM
1fastbusa's Avatar
so with a 03 zo6 what all would you need to run the 440" ls7 block
and what about a 05 c6?
Old 04-06-2007, 08:04 AM
For an '03 car you'll need the cam and knock sensors harness adapters to run our LS7 440 engine! We keep them in stock and they run about $60.
For an '05 you'll need just what you have already.
__________________
Quick Reply: Have you heard about the new Scoggin Dickey Big Bull LS Motors 413,427,440 cid?
