P0758b trans not shifting after car ran hot
i tried a search its not working as usual i need some help from the tranny guru's i have a 2000 formula with a 4l60e stock stall the car ran hot on me today well i have taken care of that issue now the trans fells like its in neutral and setting P0758b code. the trans fluid smells ok not burnt and fluid color is good nice and pinkish red like its suppose to be i baffled did i burn up my tranny or did maybe the fluid temp hot to the point that the solenoid is not letting the trans shift. somebody help me
reverse works fine and it takes off in first then shifts to second then feels like it goes into neutral or some type of a stall of second instead of shifting to third im prayin in its a simple as solenoid
well im gonna pull the pan see what happens if its okay i will replace the solenoid. i need to a picture of which solenoid it is im not sure there is a few in there
pm sent. okay so inside the pan looks okay no more debris than naturaly be there some but not much. pretty much like the first time you pull a pan off of a perfectly working trans to service it. i didnt do a good job describing the symptoms. it feels fine in reverse and first then it shifts to second second is fine then it just dont shift just stays in second i drove it agian just before i pulled the pan last nite so maybe the better explaination could be more helpful cause with it acting like that and what it looks like i believe it just may be the solenoid and nothing else im going to the dealer to get the solenoid in a few minutes
okay awesome i thank you for taking the time to answer my questions i will let you know the outcome goin to pick those up now look pretty easy to change out just a clip. im an experienced tech thats a newb with working on auto trans other than general maintence and removal and replacement
okay so i changed to solenoids it was simple gonna go button it up take it for a ride thanks performabuilt you guys got my approval if i do end up needing a trans ile know who to call
well it was the solenoids i put it back together and it shifts like new no issues no codes no slipping.
+100 for performabuilt i dont own any of there products yet but he still pointed me in the right direction i believe that if i have any trans needs of know anybody who does im gonna refer them to performabuilt.
