Calling all Cam experts!! Can someone help me ID these cams???
Old 04-04-2007, 07:14 PM
litle88's Avatar
Default Calling all Cam experts!! Can someone help me ID these cams???
i just got 2 cams from a friend but he forgot to tell them apart, both cams are gm cams and both measured 525 on the lobes according to the micrometer, Now the first one has the numbers:
1721
S 17
1248
just like that on the end with like a square that looks like "checkered inside the square", or like a "crossword puzzle" like.which GM cams have right?
The second has no marks on the sides but has like a "blue marks" between the lobes and also in between the lobes are some very small numbers engraved in there. I believe they read:
10:516
@8002
just like that.
All help will be greatly appreciated!!!!!!!
Old 04-05-2007, 12:54 AM
litle88's Avatar
Come on is there anyone out there??
Old 04-05-2007, 02:05 PM
litle88's Avatar
What come on ls1 techies!!!!!!!!!!!!!!
Old 04-05-2007, 02:52 PM
lt1_fool's Avatar
The most lift on a stock ls1 cam, was from 98-00, and that was around .490.
01-02 was like .460-.470.
.525 could be a hotcam
Old 04-05-2007, 03:15 PM
litle88's Avatar
The thing is they both measure .525
thanks for your input!!
anyone else!!!!
Old 04-05-2007, 05:44 PM
litle88's Avatar
OOOHHHH come on 84 people seen this and no experts?? what gives!!!!
Old 05-08-2007, 11:51 AM
litle88's Avatar
Ttt...
Old 05-08-2007, 11:54 AM
litle88's Avatar
I know that they are GM cams can anyone tell me if one of these is the hotcam?
can you compare the numbers on your hotcam or z06 cam or even an ASA cam?
Old 05-08-2007, 12:43 PM
oange ss's Avatar
GM Hot Cam and 2001 Z06 cam...
Old 05-08-2007, 01:54 PM
litle88's Avatar
Thankyou orange for your response!!
But which one is which and how do you know? thanks
Old 05-08-2007, 02:02 PM
litle88's Avatar
Anyone else wanna chime in I could really use the help. there is not one place in my area that can dr. these cams!
Old 05-08-2007, 05:11 PM
litle88's Avatar
158 views, 2 replys!!!
Old 05-08-2007, 05:17 PM
Juiced's Avatar
anyone else!!!!
I highly doubt that.
The Lift Given on ls1 cams is asuming a 1.7 rocker ratio if you had .525 tappet lift it would be a .892 lift cam.
Check the End of the cam o see if anything has been scribed in.
If Not have it cam doctored to find out.
Old 05-09-2007, 09:44 AM
litle88's Avatar
No one on here has a hotcam, ASA or a z06 cam so i can get some reference numbers to compare them with?
Old 05-09-2007, 10:50 AM
bww3588's Avatar
sell me one if they are ASA cams.
Old 05-09-2007, 10:58 AM
litle88's Avatar
No problem bro, will do!!!!see if you can help me, please. I have no one in my area that cam doctors!!!!!!!sux
Old 05-09-2007, 12:09 PM
GR33N GoblinM6's Avatar
my ASA cam only had 267A on the end of the cam as i recall.. dont know about the other cams..
Old 05-09-2007, 02:00 PM
litle88's Avatar
Thanks green!! anyone else?
Old 05-09-2007, 03:16 PM
bww3588's Avatar
dude, even if you did its expensive.
Old 05-09-2007, 04:29 PM
litle88's Avatar
I got these for free!! from mike Alsop the guy from spike tv's bullrun!!so it cant be that expensive, he forgot which one was which! he had about 4 other cams!!
Quick Reply: Calling all Cam experts!! Can someone help me ID these cams???
