View Poll Results: How many miles is too many when thinking about a cam swap?
>50k
5.81%
>75k
14.19%
>100k
27.10%
>125k
52.90%
Voters: 155. You may not vote on this poll
Highest mileage for cam swap *POLL*
Old 04-05-2007, 09:45 AM
lt1_fool's Avatar
Default Highest mileage for cam swap *POLL*
How many miles is too many for doing a cam swap?
lt1_fool is offline
Old 04-05-2007, 09:46 AM
Studytime's Avatar
Again, common sense prevails here. Does your car have good oil pressure? Does it smoke? If it seems like it is in decent mechanical condition, go for it.
Ben T.
Studytime is offline
Old 04-05-2007, 09:50 AM
lt1_fool's Avatar
Well, assuming everything 'seems' in good shape, no smoke, good oil pressure, etc...
lt1_fool is offline
black01_WS6's Avatar
I put ime in at 80K and don't have any problems. It all comes down to how the engine was cared for. I know a guy that is putting a cam in his ride and has 180+ on his.
black01_WS6 is offline
lt1_fool's Avatar
how many miles do you have now?
lt1_fool is offline
Old 04-05-2007, 10:13 AM
J's99Zrated's Avatar
Do it when ever you want. What is the worst that can happen, you have to rebuild a high mileage engine? If it is going to go, I bet the cam won't make much of a difference on the timing.
J's99Zrated is offline
Old 04-05-2007, 10:53 AM
Bad Blu Formula's Avatar
I did mine at 124k, no problems yet. Like Studytime said, as long as the motor is in good mechanical condition you should be fine.
Bad Blu Formula is offline
Old 04-05-2007, 10:58 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I'll be in there before 40k
BlackScreaminMachine is offline
Old 04-05-2007, 10:59 AM
Studytime's Avatar
Wear should be the deciding factor on if you want to cam it or not... the thing is mileage won't be a good indicator of wear. It's the best we have, but not a particularly good one. One car could be on its last [motor's] leg at 65K miles, and yet another could be in pristine condition mechanically at 185K miles because of a superior maintenance program and better care throughout its life.
Ben
Old 04-05-2007, 11:00 AM
Internet Mechanic
LT1's seemed to have the high milage cam swap issue, due to having 2 bolt mains and if the block is used to not having it un fastend after alot of miles.
LS1's are structurally more ridgid, I would have no worries about a cam swap even at a 100k. Just be aware of cam bearings, thats bout it.
Old 04-05-2007, 11:03 AM
sobaka79's Avatar
if its its over 80-100k, change out the timing chain and oilpump (like 300 bucks as a set.),
you might as well change your pulley($200), tensioner ($125), etc etc... if you got the money get a balancer and electric water pump too...
word of the wise, if it comes off, you might as well replace it with a new piece if its plastic or rubber.
p.s. i took for granted the springs etc, you need to update your springs according to the cam if your goin to be spinnning it that high, i got an ls6 cam in mine, but i let it shift out at early bc i have OEM springs( i never see 6000rpm)
sobaka79 is offline
Old 04-05-2007, 11:04 AM
GR33N GoblinM6's Avatar
im at 114k and im doing a cam swap in 3 weeks.. my oil pressure is always 55 at idle.. 65 under throttle.. always running good.. not a daily driver anymore either..
but im not going aggressive with the cam... looking in the 220-224 range..with a lift no greater than .570.. because its not what i need
GR33N GoblinM6 is offline
Old 04-05-2007, 01:52 PM
ditty24's Avatar
80k when i did mine and its been great for the last 6k of hard driving!
ditty24 is offline
Old 04-05-2007, 02:44 PM
mxmccarter2401's Avatar
just did mine at 140,000. good time to replace a lot of things while your in there.
mxmccarter2401 is offline
Old 04-05-2007, 03:54 PM
lt1_fool's Avatar
Wow, what all did you replace?
lt1_fool is offline
Old 04-05-2007, 04:16 PM
CJDZ24_Z28's Avatar
Here is my mileage n my 1998 Trans Am and im gonna do one in like 2-3 weeks with a small cam since its my daily driver. My 01 SS is gonna get the big cam
CJDZ24_Z28 is offline
Old 04-05-2007, 05:08 PM
GeArBaNgEr56's Avatar
I know one guy who just cammed it at 120k and one of my buddies has 149k on his and its cammed. They both run like the day they were bought.
GeArBaNgEr56 is offline
Old 04-05-2007, 05:09 PM
Dom
Dom's Avatar
This poll made my day. I thought my only option was to save up for a rebuild. I'm at 96K and want a cam this summer.
Dom is offline
Old 04-05-2007, 05:16 PM
sprayin'99ss's Avatar
102K and doing a MS4 swap next weekend! Not my daily though.
sprayin'99ss is offline
Old 04-05-2007, 07:13 PM
quick346's Avatar
yeah as long as it runs good and has been taken care of (oil change wise) i would not worry about it
quick346 is offline
Quick Reply: Highest mileage for cam swap *POLL*
