Adapt to Factory Tach????
We are intending to use an aftermarket tach we happen to have on the 4cyl setting while we are getting the engine up and running (LS1 into 67 Camaro). At some point, we want to hook the factory tach back up though. Has anyone done this? If so, how?
Is it a cable tach like the early vettes or electric. I am assuming it is eelectric I'm gettin rsty on old iron. I believe It is the same signal that gm used all of their tachs up until they went to the gen three motors and if thats the case the signal can be changed internally in the pcm using a tuning suite like hptuners etc.
It's electric. You can rescale the tach output in the PCM using any standard tuning software (I used HPTuners), or if you are farming out your PCM tuning you can tell your tuner to scale it for a standard 8cyl tach.
If you get it hooked up and the tach bounces, you may need to put a filter on it like this one: http://www.camaros.net/techref/electrical/tachfilter/
If you don't get any output, you might try a tach adapter like the Mallory #29078 (figure B wiring in the instructions).
sawzall wielding director
You can either use HP Tuners or EFI Live7 to change the tach output.
There are also a few places that make adapters, dakota digital is one of them. I don`t really see an adapter being advantageous in your situation though since you will need to change other parameters in the PCM with HPT or EFIL7. If the price of those programs scares you off, you can also have the PCM reprogrammed by someone else. Both Speartech and jesse at wait4me reprogram PCM`s for conversions.
At this point in the game, whats another $1K??? I am much more worried about us getting into the computer and screwing something up. I imagine the cheap handhelds won't do what we want to do, they seem to be for changing the shift points in the A4. The guy we bought the engine from did reprogram for us, but we didn't even think about this parameter. He would be happy to make changes for us, but we do know that at some point we are going to have to learn how to do it ourselves....
At this point in the game, whats another $1K???.............lol yes that is what I say my swap camaro is a b.o.a.t break out another thousand.........I changed mine to auto meters
