4L60 to TH350 swap..what do i need?
Old 04-05-2007, 09:56 PM
pirate3's Avatar
Default 4L60 to TH350 swap..what do i need?
I read the one thread about it just seeing if anyone else had done it and had any "special" tips or parts I might need.
Old 04-06-2007, 05:38 PM
juicedls1's Avatar
definitly get the BMR crossmember, if u have lond tube headers trim the ears on the sides (it makes for a easier install) but make sure u keep the bolt holes there for ur shield! i had to have my driveshaft lenghtned about 1.5 inches, and i also had to have my front o2 sensors moved back cause they hit my shifter (pacesetter longtubes) and i also reused my factory shifter! Good Luck!!!
Old 04-06-2007, 06:59 PM
pirate3's Avatar
do I need the spacer for my convertor?
Old 04-07-2007, 01:57 AM
One Bad Z's Avatar
they make converters now that have the ls1 pattern
Old 04-07-2007, 08:31 AM
smoknta's Avatar
Get the correct length tail shaft, and you can use the stock length drive shaft.
