Will OEM C6 Z06 wheels fit on my C5?
Old 04-05-2007, 10:47 PM
LS1TECH Sponsor
JeremyF's Avatar
Default Will OEM C6 Z06 wheels fit on my C5?
Ok I am sure this has been discussed before. I could not find the answer though. I am interested in the OEM wheels/tires because I believe they will be a bit lighter than aftermarket replicas. I believe they may stick out a bit in the rear but its for a road race application so no big deal. Rub inside? any pics? whos doneit before? any input I do appreciate. Thank you all and God Bless
Jeremy Formato
Old 04-06-2007, 10:00 AM
Xsta Z 28's Avatar
Not without spacers/adapters . . . the offsets are WAY off.
Old 04-08-2007, 03:16 PM
LS1TECH Sponsor
JeremyF's Avatar
Thank you for the reply. I was begining tothink no one would touch this one. I have some spacers but how big? Also Am I correct to assume that the STK wheels are light than 99% of replicas?
Thank you, and Happy easter!
Jeremy
Old 04-08-2007, 06:31 PM
Deep Blue's Avatar
The fronts will fit without a spacer. The rears will need one. Some one claims to have had a spacer custom made, but I used a hubcentric bolt on adapter, 1.25 inches wide. Weights on the Oem wheels are 21.5 lbs for the front 18X8.5 and 23.5 lbs for the rear 19X10.
Quick Reply: Will OEM C6 Z06 wheels fit on my C5?
