cleaning up the gunk
Old 04-05-2007, 11:30 PM
landstuhltaylor's Avatar
Default cleaning up the gunk
at first i was thinking ofusing a brillo pad but then i worried about scratching the paint. any ideas for free/cheap cleaning?
its mostly rust and dirt
EDIT: image below
Old 04-06-2007, 12:42 AM
SSilverSSurfer's Avatar
what is that? pics are too big, too close
Old 04-06-2007, 12:55 AM
97REDZ28's Avatar
It looks like your wheels have a disease or something. All joking aside, try using Windex. I swear you can clean anything with that stuff!
Old 04-06-2007, 12:59 AM
Donohue96M6Z28's Avatar
i think the wheels are ruined.
Old 04-06-2007, 01:25 AM
ill put up different pics in the morning
Old 04-06-2007, 08:08 AM
xBROKEx's Avatar
when you take a pic like that up close, use the macro function on your camera, its usually the button that has a tiny pic of a flower
Old 04-06-2007, 10:55 AM
Roadhouse's Avatar
I've used simple green and a tooth brush with success. Just make sure the wheels are cool before spraying so they don't get stained.
Old 04-06-2007, 11:17 AM
Old 04-06-2007, 12:02 PM
01FormulaTA's Avatar
^^^is that sand all over your car??? oh and your missing 4 lugs!
Old 04-06-2007, 12:27 PM
its snow and dirt. im in the process of restoring the car so its not in the best shape right now. the lugs are all there its just hard to tell.
Old 04-06-2007, 12:28 PM
i see 3 lugs.
Old 04-06-2007, 01:32 PM
Originally Posted by Donohue96M6Z28
i see 3 lugs.
went back and checked and you are right. two of those lugs are not what is supposed to be on there, and two more are missing on the other wheels.
Old 04-06-2007, 02:00 PM
xBROKEx's Avatar
try using mothers aliminum polish, if it wont get it out then its not comin off without having to sand it
Old 04-07-2007, 10:45 AM
Nate81Camaro's Avatar
Try using a pressure washer w/ HOT water. After/If you get the gunk off them, try using mother's.
Let us know if you get em cleaned up!
Old 04-07-2007, 11:10 AM
will do! its only that one wheel but its low on my list of priorities.
Old 04-07-2007, 07:22 PM
Roadhouse's Avatar
Be careful doing that, that could knock the clearcoat off too.
Old 04-07-2007, 08:07 PM
^^What's the difference from what I said to going to a car wash? - The HOT water part?
