any lt1s in the 11's
So are there any bolt on lt1s in the 11s? Doesnt matter if its a 11.9999. My goal is just that, to hit a 11 in my car. Its got major weight loss, suspension, every bolt on and at least a 150 shot, hopin to top out at a 200 shot. I got gears and a built trans and a 3200 stall. Car prob weighs prob in the high 3100lbs range. Motor wise ill have 1.6 rockers and a valve train, got longtubes with bullets dumped off the headers. Any one running a 11 sec. lt1?
Do you have a cam to go along with that valvetrain? If not then why waste time just throwing massive amounts of spray at a motor thats not taking in enough air for what your trying to do. Also what swize gear are you running. The car looks like it would hook pretty good but if you launch on the 200 shot and cant cut good 60's with it i think the car would be in the mid to loww 12's but a 200 shot properly driven should make it into 11 second territory.
well im doin the valvetrain for the 1.6 rockers and i plan on doin a cam later just not right now and if im spraying a lot then i dont want any valve float and would want a tight valvetrain. Im pretty positive i can get the car to hook good. Any other thing you can think about to help me get there.
I'm in the 11's with nothing but bolt-ons and a 100 wet shot, all my mods are listed in my sig. If you have any questions about getting into the 11's with an lt1 and bolt-ons feel free to ask.
LS1TECH Sponsor
11.31 on stock engine except for valve springs and rocker arms. Pushing air with a Procharger though.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
94 z28 A4
stock motor with cc306 cam, 4.10's, 3600vig, 28x10.50 slicks, pacesetter LT's, dynotune 150shot, just a base line tune (after i put the cam in last week), CAI, torque arm, LCA
I haven't drove it around yet I just had to make it to the track rental.
shaun herron has the bolt on record, i think he's running mid 11's
that car went on a serious jenny craig and suspension work to get it there though
http://www.herronperformance.com/store/
if you count a 120 shot as a bolt on, i'm runnin 11.9 with mods in sig. slipping trans (getting that fixed as soon as my financial aid comes in this summer semester )
12.29 N/A full weight with a stock 3.23 10 bolt. In the middle of a 9" install with a 3.89 gear. Shift points still stock between 5800 and 5900. With some shift point work and the deeper gear, better LCAs and a adj. torque arm to get my 60' down from 1.70 range, I think I can break 11s all motor. After that I'm gonna try a 100 shot. We'll see what happens.
Mec
Mec
Im stuck at 12.22 / 110 mph with a cam only 1995 a4 z28, im not goin nos so i guess ill have to put it on a diet, im looking at fiberglass hoods now because the a/c and interior are staying!
Jason
Jason
