Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt
I'm looking to purchase the Complete Gear Package for GM 7.5" 10 Bolt from Thunder Racing and wondering if the upgrade is worth it. I would be going with the 3.73 gear ratio and the kit seems it will add some strength to the rear end, though it's not a 9" or 12 bolt.. I just don't have the money for that.
The package comes with;
MOTIVE Gears, in your choice of ratio...3.42, 3.73, 3.90 or 4.10
Or, STRANGE Gears (2 or 3 series carrier) for $35 additional
RATECH Complete Gear Installation Kit
2 Quarts RED LINE or ROYAL PURPLE Synthetic Gear Oil
1 Bottle GM Limited Slip Differential Additive
TA Performance Rear End Cover Girdle Engraved w/Thunder Racing Logo
TA Performance Stud Kit
Sorry if this is a repost - I tried searching but only gives me a blank page.
14 Second Truck Club
GM and Ratech do not make bearings. If you have a choice I would reccomend Timken bearings. All the major brands are good, Korean bearings are usually junk, with chinese right behind. US, japanese are both pretty good.
Originally Posted by eagleknight97
Where can you get Timken bearings at?
might consider trying the mikronite process.
timkin makes gm's bearings
yes the kit is worth it
the solid pinnion spacer is a pain in the *** to get set rite
it involves taking the rear end apart several time to get rite
because basicly you cant go off of the used crush sleve
you have to assembly the rear end pinnion depth has to be rite and back lash has to be rite with new crush sleve used with the proper turning torque of the pinnion as well then take it all apart mesure the new crush sleve that has been crushed and shim the solid spacer to the same measure ment.
it works well when set up rite just takes for ever
the bearings in the thunder kit are top notch when i do installs on rear ends thunder is my supplier i have never had a rear end fail yet. ive only had 1 guy brake about 6 teeth off of a ring gear with a six speed car only becazuse he launched it at about 5 grand with 28 in slicks
