Wet Sand ???
Wet Sand ???
Can I wet sand my tail lights? I am going to do my headlights this weekend and wanted to make sure it was safe to do on tail lights as well.
I figure I'll start with 800 or 1000 and work to 1500grit. then use that 3 step novus plastic polish.
Any thoughts?
Thanks
Any thoughts?
Thanks
Any thoughts?
Thanks
Any thoughts?
Thanks
I wouldnt use anything but 2000 grit. That will be enough.. Always make sure that the lights stay wet! and polish it out with a PC or rotary with some 3m polish that takes out 2000 grit sandpaper marks..It will look great!!
That can't be stressed enough!
As long as you walk up the grit being sure to remove all the marks from the previous grit you will be fine. Depending on your area, you may have to go to a special store to find all the in-between grits.
On my exports, I removed the casting marks and stamped letters. Started with 400 on a sanding block for the marks & letters. Then by hand 600, 800, 1000, 1500, 2000. Keep them all wet and make circles not back and forth. Follow with a good polish. I use Novus 3 step, always with good results.
any polishing !!!!!!!!
www.eastwood.com they got it all, and tech info on their web site ..
