Tools & Fabrication - Mild Steel 2-1 Exhaust Merge Collector
Rompn
04-06-2007, 02:58 PM
I am looking for a company that sells a 2-1 merge collector for a custom exhaust I'm building. Few spec's though... needs to be mild steel, not stainless, 16g is preferred, 2 1/2" inlets to a single 3" outlet. PLUS, one of the inlets needs to be straight and the other needs to be at about a 45* angle. I have used the one Flowmaster sells in the past however that one won't work without some modification for this. Now, I could build this from scratch however I have been sketching it out to get the math correct and it's been a little difficult. I am going to experiement this weekend with some cardboard for a template but would rather keep this project moving forward by just purchasing one. Any help is appreciated. Thanks.
JGKadell
04-06-2007, 04:00 PM
have you tried www.drgas.com or pypes?
JGKadell
04-06-2007, 04:01 PM
http://www.drgas.com/store/product.php?productid=17&cat=1&page=1
http://drgas.com/store/files/master/product_images/UMC_01.gif
Rompn
04-06-2007, 04:09 PM
That's extremely close to what I'm looking for. That 90* inlet needs to be around the 45* mark but I could always cut where I needed I guess. $115 for it is pretty damn steep though.
Also, I need a few good quality, mild steel v-bands for this setup as well. Ideas?
mrdragster1970
04-06-2007, 04:58 PM
Build it
Rompn
04-06-2007, 05:20 PM
Build it
This is the route I'm leaning towards more and more. I am thinking about trying this way of building it (an awesome link if you have never seen it done this way)... http://www.theturboforums.com/smf/index.php?PHPSESSID=d69e54c972d4e0097efa61c9f81378 9b&topic=65147.0
xfactor_pitbulls
04-06-2007, 08:42 PM
If you have doubt or lack the tooling, just run the Dr.gas and cut it where you need to. $115 isnt that much, you are not talking about saving anything significant if you buy some cheap POS.
mrdragster1970
04-08-2007, 10:02 AM
If time is an issue and u don't care about the money, use this one cut to the proper angle u need and buy, borrow or rent an expander. I bought 2 hand expanders (2 sizes) and u will be all set. I don't remember, but they weren't that expensive.
Good luck.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
