Stock Bottom End, Stock Head A&A P1SC Dyno Numbers
Old 04-06-2007, 03:08 PM
FRCBobby's Avatar
Default Stock Bottom End, Stock Head A&A P1SC Dyno Numbers
Took the car yesterday to have some tuning done by Phillip "Bluecat" Smith.
Here is what he got out of it.
Mods are as follows:
A&A P1SC Procharger 3.85 pulley 11psi
G5XB cam
LS6 Intake
Ported Throttle Body
Long Tubes
SLP Powerflo
ECS Methanol kit
60lb Mototrons
MSD Boost A Pump
Old 04-06-2007, 03:16 PM
L"SS"1's Avatar
Wow great numbers Keep up the good work!
Were you getting any knock @ full boost with that meth kit? I am boosting 6lbs on stock heads and big cam car and shootong for 500-525. So far I am at 460hp with no tuning and without the meth and just curious how much that meth it helped.
Old 04-06-2007, 03:19 PM
FRCBobby's Avatar
no knock. The meth is awesome.
Old 04-06-2007, 03:23 PM
Rickys S/C Z28's Avatar
man i hope mine is that strong!!!! great ######s
Old 04-06-2007, 03:27 PM
L"SS"1's Avatar
Thats exactly what I wanted to hear! Are you doing straight meth or are you doing a mix?
Old 04-06-2007, 06:29 PM
FRCBobby's Avatar
straight meth is what I am running. That was recommendation of ECS.
Old 04-06-2007, 06:31 PM
pakisho's Avatar
Damn. Stock bottom end? That **** is gonna blow.
Old 04-06-2007, 06:43 PM
FRCBobby's Avatar
yeah stock bottom end. I don't run the car very often, mostly just cruise it around so I am hoping it will last a pretty good while.
Old 04-06-2007, 06:51 PM
pakisho's Avatar
Its going to be directly proportional to how hard you drive it.
Old 04-06-2007, 06:53 PM
FRCBobby's Avatar
Oh yeah I know that. I normally just cruise it around easy, but you know on occassion you just have to get on it a little. Also, there will be a couple of 1/4 mile runs.
I have plans of building a bottom end next winter already though. So as long as it holds out til then I am fine.
Quick Reply: Stock Bottom End, Stock Head A&A P1SC Dyno Numbers
