PCM Diagnostics & Tuning - Removed some parts now car won't start..
02' hawk
04-06-2007, 03:27 PM
I removed the AIR pump and a computer that had a couple of wires and a cable that came out of it that ran to the throttle body. So i removed it because i needed more room for a filter in there and i don't have cruise controle anymore (TH400) tranny. The car started probably twice and now it wont start period! I even hooked everthing back up and still nothing. I posted this in here because i think i need to turn off the AIR pump and maybe something else (for the little computer i also removed). Can someone tell me what i need to turn off. I have EFI Live.
02' hawk
04-06-2007, 04:58 PM
Well anyways...... pulled a plug wire....no fire... WTF. Unpluged the ign. coil packs....no power...WTF..... Swaped out the Ign. relay and with a fan relay and then fired right up...... Off to the local parts house for a new relay...
Fedge
04-06-2007, 07:48 PM
funny, i removed my AIR pump and some little thing next to it and had the same problem, but when I swapped the relay, i still got no fire! UGH!
LiENUS
04-06-2007, 10:01 PM
Use the air pump relay in place of the ignition relay (assuming they're the same relay on the LS1).
LiT1_up
04-06-2007, 10:40 PM
I had no problems when I removed mine. Just lucky I guess.
minytrker
04-06-2007, 11:38 PM
do you have any codes?
SSmoked!
04-07-2007, 11:59 PM
DAMN!! I wanted to remove my air pump tomorow!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
