Read my bearings! Pics inside motor teardown!
Old 04-06-2007, 03:43 PM
CoronaL's Avatar
Default Read my bearings! Pics inside motor teardown!
Explained awhile ago about the "snowflake" appearance of the bearing on one of the main caps I pulled. Didn't really get a reply. Anyway, if anyone can comment on the main bearings and the crank I would appreciate it.
I think the crank is fine, but I'm not sure why the main bearings were so pitted or had these "flecks" in them. You can feel the pits with a fingernail. The crank is smooth.
Cylinder liners I'll grab pics of later. My camera battery died . They appear ok, but there are some "stains" on some of the walls.
Thx
John
Old 04-06-2007, 04:15 PM
MCBRIZ28's Avatar
where these factory bearings. Looks kind of like the pitting i have seen on bearings out of some menthol fueled engines I have took apart after a long race season where owners would not change oil regular enough to keep water in oil down. Have never seen it that bad on gas burning engines.
Old 04-06-2007, 04:24 PM
CoronaL's Avatar
yep factory with @20k miles on LS6 pull due to oil burn issues
motor had been sitting @2yrs prior to teardown
Old 04-06-2007, 04:36 PM
CoronaL's Avatar
cylinder pics with wifes cam didn't turn out great but still can see what I'm talking about
Old 04-06-2007, 04:37 PM
MorePowerPlease's Avatar
I agree with mc. Looks like water corrosion. Bearings are softer metal than crank so pitting is easier.
Old 04-06-2007, 04:41 PM
CoronaL's Avatar
well I'm ok with that, since motor sat so long I can see where that would happen!
Do the liners look ok?
Really would like to just re-ring the pistons and slap it back together with some new bearings
thx
Old 04-06-2007, 05:42 PM
LS1C5Vette's Avatar
Def pitting on the bearings, Crank looks good BUT just because it looks ok does not mean it always is, While you have the engine out I would spend the extra $50 and take the crank to a known machine shop and have it mic'ed (just to be sure, you wouldnt want to spin a bearing and do this all over, do it right the first time!) and polished also while the crank and pistons are out I would give the cly's a good hone (you can rent a hone from autozone), then you should be good to go with some new rings and bearings
Old 04-06-2007, 06:24 PM
CoronaL's Avatar
sweet
thx
will do
will a standard SBC hone be what I need then from autozone?
The one that goes on a drill and you just run it up and down a few times?
thx
Old 04-06-2007, 07:37 PM
1997bird's Avatar
Depending on the type of ring used determines the grit on your honing tool. I would be carefull to observe the piston ring manufactures suggested grit before doing your honing.
Old 04-06-2007, 07:47 PM
CoronaL's Avatar
rgr that
thx
Old 04-06-2007, 11:38 PM
LS1C5Vette's Avatar
Get er' done!
