New LS1 Owners - Newbie Tech - Cut Out
5301113
04-06-2007, 04:54 PM
I want to buy a cut out for my car but i don't know what size to buy it and were to put it. I would like one that i can open with a push of a button . Can someone give me some info???? :drive:
hawaiianpunch01SS
04-06-2007, 04:56 PM
most ehaust shops can d it for around $50 or less plus the cut out
Kalgorn
04-06-2007, 05:04 PM
QTP makes a great electronic cutout. I have one on my car. The previous owner (who works for QTP) had one put on. He had the switch mounted in the ash tray. I love it.
I don't know what it costs and I'm not sure on the size... I think it's 2.5" but an exhaust shop should be able to make even a 3" fit I'm sure.
Allergik2dyin
04-06-2007, 05:20 PM
www.quicktimeperformance.com has good info on cut-outs. you will want to look for an electric or e-cutout. Jegs also has them at about the same price. an exhaust shop can do it for around $50.
gyrene2003
04-06-2007, 05:25 PM
best place is under the passenger seat, were the little bump is. its almost like it was ment for a cut-out.
5301113
THANKS. That helps alot :)
Intense
04-06-2007, 07:02 PM
QTP or DMH both are great!
aaron653
04-06-2007, 09:17 PM
you definately want a 3 inch cutout
Razorbackfan
04-07-2007, 12:35 AM
My car has it installed below the driveshaft close to the rear axle. The switch is mounted in the ashtray. It's a QTP and it's pretty cool. I don't notice any difference in power but it's definately got the cool factor.
Jeff
Mr.Powers
04-07-2007, 01:08 AM
curious... could it be installed right behind the longtubes and before the cats on each side? Basically leaving only open headers?
billyb
04-07-2007, 12:55 PM
how about the ground clearence factor ?????
2QUIK4U
04-07-2007, 01:44 PM
It doesnt really sit any lower than the stock exhaust. Just be sure to angle it so that it points to the side of the car not straight down and the clearance should be fine.
thaigleshmk
04-07-2007, 10:18 PM
+1 on that??? Anyone??
hawaiianpunch01SS
04-07-2007, 10:24 PM
+2...
aaron653
04-07-2007, 10:38 PM
i've heard that you need at least 18 inches of pipe after the headers..or your O2's will mess up
JerseyLS1TA
04-08-2007, 01:23 PM
QTP 3" manual cutout, no loss of ground clearance and underneath the passengers side seat is a perfect place. Cost $35 to have installed
http://i4.photobucket.com/albums/y143/AssKickinLS1/100_1116.jpg
http://i4.photobucket.com/albums/y143/AssKickinLS1/100_1115.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
