Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Issues w/F body 16" rims on back of C5's
Old 04-06-2007, 05:05 PM
02SCVette's Avatar
Default Issues w/F body 16" rims on back of C5's
Ok, so why is it that we can't put the inexpensive TA/Z28 16's on the C5's for the track? If it hits the caliper, can't they be ground enough to make them work?
I thought they'd fit but was recently told they won't. I knew I should've tried my TA rims on before I sold it.
Old 04-06-2007, 05:23 PM
GTFORMULA's Avatar
I had 16x8 99 T/A wheels bolted to my Z06. You must grind on the upper ball joint area. It can be done. I also used a 3/16 spacer to get them away from the brakes. I have a set of T/a wheels with 28x10-16 full slicks with 3/4 tread for sale if you need them ,Ill include the spacers too. Pm me if interested.
Old 04-07-2007, 06:47 PM
02SCVette's Avatar
Thanks GTformula. So the strength isn't compromised by the amount of grinding needed? You wouldn't have a picture of it after grinding would you? I've got some 255/50/16 BFG DR's sitting around that I wanted to use but just need the rims - and a spacer it looks like.
Old 04-07-2007, 09:20 PM
GTFORMULA's Avatar
Sorry no pics. It was one of those rush for the track later that days. There is not enough material taken off to lose strength.
Old 04-07-2007, 09:38 PM
02SCVette's Avatar
Thanks for the info!
Old 04-08-2007, 07:43 AM
Brad02Z06's Avatar
I didn't use any spacers just grinded a little.
pics here
http://forums.corvetteforum.com/show...ight=brad02z06
Old 04-08-2007, 07:13 PM
02SCVette's Avatar
pics here
Thanks for the link and the info. Great idea for a cheap and light option.
