Jus got c6 z06 rims..wont fit in rear??
Old 04-06-2007, 05:10 PM
z28 97's Avatar
Default Jus got c6 z06 rims..wont fit in rear??
I jus got them and put the fronts on no problem....18x9.5 all the way around...the rears dont sit flush like the front....Need help...Thanks Jason!!!
Old 04-07-2007, 12:30 AM
z28 97's Avatar
can any1 help?
Old 04-07-2007, 12:33 AM
Z28LS1camaroguy's Avatar
did you jack the car up by the pumpkin on the rear end??? if not then the bumpstops will keep you from putting the rear wheels on.
Old 04-07-2007, 07:18 AM
z28 97's Avatar
thats probally the problem...but i am not sure what the pumpkins are...so well find out today...
Old 04-07-2007, 07:49 AM
funnelone's Avatar
The center section of the rear end.
Old 04-07-2007, 11:02 AM
1BadTA13's Avatar
yeah....jack it up by the big round part in the middle of the rear end...they should fit no problem if you do that..
Old 04-07-2007, 11:25 AM
z28 97's Avatar
what is the bumpstop...i tried jackin it up differently but it still wont fit...The problem is the wheel jus wont fit flush against the rotor....i dont know what to do...
Old 04-07-2007, 11:35 AM
ap2000z28's Avatar
looking at your name I take it you have a 97 z28? If so i am pretty sure I have read on here that you need to grind down the rotor a little as they are a tad bigger then the ls1 rotors that the wheels are made for? I could be totally wrong hopefully others will chime in
Old 04-07-2007, 01:05 PM
z28 97's Avatar
what do you grind down?
Old 04-07-2007, 02:38 PM
68z28's Avatar
No don't grind down the rotor. You need to grind the inside hub of the wheel. Don't worry, you will never notice from the outside. The rear hubs on the the LT1 cars are 1mm larger in diameter than the fronts. This problem was later corrected(I though 97, but I guess it's 98). This issue wasn't accounted for on most aftermarket wheels, and thus the wheels won't fit over our rear hubs. I had to buy a dremel tool from sears for the project. Just slowly and evenly grind the center hub out of the wheel. Take your time and make sure they fit right and flush when you are finished. The first time I used a grinding stone bit, but after I rotated my tires I found a metal cutting bit that did the job much faster for the second two wheels. This isn't an extremely common problem on LS1tech because most of the cars on here are..LS1's without this issue. It's well documented on cz28.com. I did this on all four of my 18x9.5 Chrome C6 wheels without any issues.
Old 04-07-2007, 04:08 PM
ap2000z28's Avatar
There you go..sorry for saying grind the rotor I knew you had to grind something! Post up pics when you get them on
Old 04-07-2007, 04:10 PM
FalseErr0r's Avatar
for my 10.5 wide z06 wheel i had to get spacers on the back.
z28 97's Avatar
yes i will be grinding them and puttin them on shortly jus waiting to borrow someones dremel....Thanks for the help guys...
Old 04-09-2007, 02:09 AM
Donohue96M6Z28's Avatar
if you dont have a dremel. You can use a metal file. it only takes a couple minutes.
