Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
y-pipe ????
Old 04-07-2007, 04:51 PM
1slowls1's Avatar
Default y-pipe ????
I currently am running the qtp header/y-pipe im wondering if it would be better to just get a y-pipe custom made to fit it?? Currently mine right now is banging around and just over all poor fitment. What I want to do is possibly get a y-pipe made to fit 2 elec cutouts maybe 1 not sure yet, two cats and a magnaflow cat back frankly im a little sick of getting pulled over for loud exh, ill do good for a few months then bang i get pulled over 2-3 times in a month i mean come on its not really that loud. i was goin to use this money to buy a 90/90 set-up but i think doin this will make more sense right now. Plus i cant stand that banging around anymore and i hope this will fix it for the most part. what you think anyother suggestions???? Oh yeah and which cutout too go with and cats i was thinking magnaflow cats.
Old 04-07-2007, 05:36 PM
tektrans's Avatar
Probably just needs a tug or two when it's nice and hot and it won't bang anymore.
Let the car run a bit then wedge a prybar in there and nudge the exhaust away from the floor, it works. From what I've heard the QTP stuff fits quite well.
Old 04-07-2007, 09:22 PM
LS1Tech Sponsor
Slowhawk's Avatar
The Y-pipe needs more than a tug.Right now it hangs too low and it's resting on the BMR style driveshaft loop.
Old 04-08-2007, 07:56 AM
tektrans's Avatar
Well that sucks. The custom dual cutout idea sounds cool especially since your having problems with your current set up that can't be fixed.
Old 04-08-2007, 09:45 AM
Krazy98Z28's Avatar
If the banging is bothering you too much before you have the Y-Pipe done, In the past people have taken a hose clamp roughly 3-3.5" and cut a thick heater house and stuffed the heater hose in between the Y-pipe and the floor of the car. Also put a heat wrap in between the hose and the y-pipe so the rubber doesnt melt. Put the clamp through it and tighten it to the Y-pipe. Keeps the Y-pipe stiff.
Although I'm not sure if thats where your banging cause Don said its against the Loop. I did the heater hose trick, only issue was I had to randomly tighten the clamp at times.
Old 04-08-2007, 09:48 AM
Krazy98Z28's Avatar
I had 2 QTP Electric cutouts and loved them. Only issue is getting them to seal when you close them, sometimes you gotta flick the switch to shut them completely. I never put RTV sealant around the rim, that might of helped with the seal
Old 04-08-2007, 09:52 AM
LS1Tech Sponsor
Slowhawk's Avatar
I'm going to say to probly but a Kooks y-pipe,cut the headers back a bit and do alittle welding. The dual cutout's are nice but they are a bitch to fit without hitting the floor or ground and this car won't really gain anything but noise.
So I say a Kook catted Y-pipe,1- QTP 3" cutout and a Magnaflow catback.Some welding and swearing should get it on there
Old 04-08-2007, 08:28 PM
tektrans's Avatar
I have a Kooks y pipe new in the box that I never installed. It's uncatted but for $175 it's a good deal.
Old 04-08-2007, 08:29 PM
TheSilverOne's Avatar
yeah with my kooks y-pipe i took don's advise to start cutting and i did. i have qtp headers/kooks y-pipe/magnaflow cat back.
right out of the box:
after being modified:
Old 04-09-2007, 12:22 AM
1slowls1's Avatar
No cats???
Old 04-09-2007, 12:34 AM
1slowls1's Avatar
where you from??
Old 04-09-2007, 05:38 PM
tektrans's Avatar
No sorry no cats.
I'm in NJ. It's still in the box so I can ship it.
