New LS1 Owners - Newbie Tech - What does your fbody idle at?
View Full Version : What does your fbody idle at?
fccs
04-07-2007, 10:10 PM
Mine is a perfect 1000rpms always start up wait 2min for it to sit there and warm up and it stays at 1000 always never above or below I found that kinda odd... lol but what is the stock normal rpm your car should idle at?
Revelation Z28
04-07-2007, 10:12 PM
1000 revolutions per mile
thaigleshmk
04-07-2007, 10:17 PM
You mean per minute?
Brief Encounter
04-07-2007, 10:19 PM
850, but I wanna get 725 so you can hear that 114LSA lope a lil bit.
fccs
04-07-2007, 10:20 PM
is it better to be lower on these cars or higher? Just thinking if I should get a tuneup or not
hawaiianpunch01SS
04-07-2007, 10:21 PM
mine is 1200 on start up and 785 normal idle. your car should idle higher ion start up (choke mode) then normal driving that is odd to me 2 i would check that out if your car is staying in warm up mode you have some more power on tap if u get that fixed!!! altho i might be wrong thats just wat i have always heard
styoung
04-07-2007, 10:22 PM
mine is 1000rpms when i first start it up and goes down to about 800rpms.
trans_am_31
04-07-2007, 10:29 PM
Mine also at 1000 rpm at startup and then goes to around 800 rpm.
Revelation Z28
04-07-2007, 10:37 PM
didnt get the joke.
ULTIMATEORANGESS
my tach reads 900RPMs.
Ferocity02
04-07-2007, 10:47 PM
redline
MavZ28
04-07-2007, 11:00 PM
I've just generally noticed it always around 1000. I actually think mines a little below that. As long its not more than 200rpm off, I really don't worry about it in general. Talk to some people that REALLY watch their cars, and they will tell you different, but for the general range, thats about right to me. My .02
fccs
04-07-2007, 11:03 PM
alright I just checked to make sure anyways but if I start the car and let it run for like 5min I timed exactly it seems to go to 900 and sit there then. Does that seem right now?
BlueonBlack01-WS6
04-07-2007, 11:20 PM
About a 1000 on mine
Rhedalert
04-07-2007, 11:22 PM
My tach READS about 500 rpm idle once warmed up and in gear. I wouldn't necessarily believe this, but at the same time, my alternator will drop charging. Just putting it in neutral raises the idle maybe ~50-100 rpm's and the alternator will kick back on. Anyone else experience this?
RPM WS6
04-07-2007, 11:38 PM
The factory preset idle speeds for ALL LS1 F-bodies '98-'02:
550rpm in gear, 650rpm in park/neutral (A4)
800rpm (M6)
Idle will be higher at cold temps and on a cold start, but those are the numbers for a warm motor.
The only way you have a different idle speed is if you have custom tuning, or something is wrong with the car causing it to idle too low or high.
Don't pay too much attention to your factory tach. Mine shows an in gear idle of about 700rpm, but my scanner always shows 550 (+/- 25rpm).
BayAreaSS
04-07-2007, 11:59 PM
1k on start up and 850-900 when warm
kill_machine85
04-08-2007, 12:04 AM
After startup mine will idle at 800-900rpm
purdueranger
04-08-2007, 07:26 AM
1100-1200 cold and 850-950 warm but I have a real healthy cam in there.
question
04-08-2007, 08:19 AM
800. :)
j99fbody
04-08-2007, 08:23 AM
mine idles between 800-900 rpm
SladeX
04-08-2007, 08:26 AM
don't trust the tach...
haven't seen a ls1 car yet whose stock tach is dead on accurate. On the dyno, I found mine to be off almost 100rpm at idle, and lagging behind badly when running it at wot.
xcead
04-08-2007, 08:47 AM
1999 T/A A4
ABOUT 1000 on start up
10 secs later 750RPMS
500-550RPMS IN GEAR
BABY RUNS SMOOTH!!!!
JTH2000SS
04-08-2007, 12:45 PM
1100 at start up, 700-725 after warm up
'Trust'
04-08-2007, 01:00 PM
800rpm (M6)
Beat me to it! /thread!
BriancWS6
04-08-2007, 01:05 PM
Mines set to 850 with tuning, idles higher on cold starts of course. My stock tach is dead on for idle and cruising. It does however have problems keeping up going through the gears, but I have a shift-lite for that.
NHRAMAN
04-08-2007, 01:07 PM
I set mine at 800 rpm's.
GXPPOWER
04-08-2007, 01:18 PM
if your ls1 is perfectly healthy. after its warmed up it should almost idle at 500 rpms. 750ish in colder weather.
your engine will run 1000-1200 rpm while warming up. thats normal. but should atleast drop to around 750 range. after i seafoamed my car my rpms when back to the original 500 Rpms after it warms up. their is no lofting or chocking. its the perfect smooth idle.
Switchblade
04-08-2007, 03:33 PM
700-800 rpm at idle.
GXPPOWER
04-08-2007, 03:38 PM
hey sup brian. car still looking wicked. i just now got my allignment fixed on mine i had a Bent Spindle Arm.
squirrelishere
04-09-2007, 01:58 PM
My car used to idle around 1k no matter what. Driving or in park. Thought it was fine. Got a tune for the car and cleared up codes and whatnot, and it's just like the rest. At start is 1k, then it goes down to around 650-700rpms.
SSwt00SS
04-09-2007, 02:05 PM
with the mods in my sig, 900 RPM. really brings out the cam lope at idle...
l337_haxs
04-09-2007, 02:09 PM
I idle around 800-900 after it warms up
Ls1Bait
04-09-2007, 02:34 PM
I set mine at 775rpm at 175*F
staringback05
04-09-2007, 02:41 PM
m6s and a4s idle differently....but my a4 idles around 500
99HorseSlayer
04-09-2007, 03:19 PM
1000 on start up 700-800 at idle
ICEMAN 31
04-09-2007, 03:21 PM
about 1200 on start up and goes to about 500 - 550 after she is nice and warm
zachd
04-09-2007, 03:32 PM
usually about 850
02silvaZ
04-09-2007, 06:51 PM
750-800
