which injectors
Old 04-08-2007, 10:03 AM
vetman1's Avatar
Default which injectors
will be upgrading to a cc306, what size injectors should i use and which brand is the best.
Old 04-08-2007, 11:36 AM
96capricemgr's Avatar
Ask your tuner what he is most comfortable with. Injectors often require tweaks besides just the sizing in the tuning and he has to be familiar with them to really nail it.
30lbs would do the trick but I suggest you go bigger just so you have room to grow.
Another consideration is different injectors are rated at different pressures so a 24lbs SVO is actually bigger than a 24lbs stock LT1 injector because Ford rates at 39psi and GM at 43.5 for the LT1 and like 58psi for the LSx motors.
I would just avoid Venom and Accel, accel is supposed to have fixed their problems but no telling how much old stock is out there.
Next injexctors I buy will be Lucas or SVO 37-42lbs.
Quick Reply: which injectors
