Another LS6 Head question?
Old 04-08-2007, 12:26 PM
SSDoubleK's Avatar
Question Another LS6 Head question?
LS6 Style Patriot Stage2 heads, will these bolt right up to a LS1? It will not let me do a search, page keeps coming up blank. Want to make sure I can still use stock push rod length and rockers with some factory GM gaskets. THAnx for the help.
Old 04-08-2007, 12:33 PM
Tainted's Avatar
yes, they bolt right up and can use stock gaskets. not sure about the other stuff
Old 04-08-2007, 01:09 PM
1320 killer's Avatar
yes you can use stock gaskets. and these will bolt in. they are a direct fit. as far as the push rods go it depends if the heads have been milled at all. You can use the stock rockers though. Good luck
Old 04-08-2007, 03:37 PM
SSDoubleK's Avatar
THanx for the response. DoubleK
