need some ignition guys
Old 04-08-2007, 05:06 PM
Taubr Unit's Avatar
Default need some ignition guys
So i dont know what it is but i hope its not my opti! At idle the car surges between 500-1500 rpms. Then if im cruising in 2 gear and keepin it at about 2500 you can feel it miss. Its not a miss where it stubles, the idle will just fall a few hundred rpms then catch its self. So its not a miss like i have a cam, more of a surging i guess you can say. And also when im cruising and let off the gas and break, the idle will drop real low to where it almost wants to die but then catch itsself again. What you guys think? My ignition system consists of:
-msa blaster coil
-taylor wires
-tr6 plugs
-6al
-dig. window switch
-adjustible timing comtrol unit
-all stock opti
Old 04-09-2007, 12:34 AM
siniSSter's Avatar
Sounds like the opti, make sure also that your plugs aren't arching. Good Luck
Old 04-10-2007, 12:28 AM
Taubr Unit's Avatar
bump, anyone else got some input?
Quick Reply: need some ignition guys
