Be prepared to lose sleep over Beehive 918's !!!!
Old 04-08-2007, 05:45 PM
AZ2ENVY's Avatar
Default Be prepared to lose sleep over Beehive 918's !!!!
If you are running Beehive 918's on your car read this thread below !!!
I was just about to install a set of them and ran across this Looks
like Comp Cams Fucked up pretty bad this time
http://web.camaross.com/forums/showthread.php?t=513175
Old 04-08-2007, 05:49 PM
chaman's Avatar
Ive seen a few threads also about problems with those in the LX forums. They are snapping like twigs in some applications.
Old 04-08-2007, 05:54 PM
vettenuts's Avatar
There have been a lot of guys here as well, sounds like Comp switched to a different vendor. I would gladly pay and extra $20 (or whatever the cost increase was that forced them to a different vendor) to have a good reliable spring, wish the vendors would realize that.
00BlueTA's Avatar
Well that sucks, good thing I switched to the patriots.
Old 04-08-2007, 06:02 PM
AZ2ENVY's Avatar
I was literally just about to go into the garage to put my 918's
on and i read this crap Does anyone have any batch numbers
to verify if mine are bad or not ???
Old 04-08-2007, 06:09 PM
nmp27's Avatar
I'll try to get mine..
Old 04-08-2007, 06:34 PM
02 BLK WS6's Avatar
I heard about this too. I have a AFR dual valve springs going in when I swap cams.
Old 04-08-2007, 10:01 PM
Jasonscott's Avatar
Crap. Just installed these springs a week ago on my car. The batch number is: 045338
Old 04-09-2007, 11:18 AM
BlueB4C's Avatar
wow, please let me know which batch was crap, I am going to the dyno on friday to have it tuned and am pushing the limits of the springs already with my cam, don't wanna have major problems on the dyno. Also does anyone know how far I should let the shop push my car as far as RPM with those springs and my 233/239? I'm sure it makes power pretty high in the band but I want a reliable car and will probably NEVER push it as high up as the shop will, I am thinking 6400 max to tell them to quit?
Old 04-09-2007, 11:21 AM
GR33N GoblinM6's Avatar
for some reason your link isnt working
Old 04-09-2007, 11:24 AM
Bad Blu Formula's Avatar
Should have gotten a smaller cam
Old 04-09-2007, 11:38 AM
BlueB4C's Avatar
Haha, I almost went bigger, I think I got a "Mid-size" cam compared to the MS3/MS4/G5x4/T-Rex/Trak.
I have a set of patriot dual springs going in towards the ends of the summer with the new heads, I just need to make it to then with a ton of daily driving and a few trips to the track.....keeping my fingers crossed....
Old 04-09-2007, 11:54 AM
gold87TBI's Avatar
Last week I saw two trucks with broken 918s, One of them had a 220/220 112lsa that one dropped a valve and made a hole in the piston and the other one was a friends truck that we were changing the heads and saw the broken spring but the valve stayed in place. This makes me worry I also have 918s.
Old 04-09-2007, 12:23 PM
00T\A's Avatar
Is this a recent batch of springs?
Old 04-09-2007, 12:25 PM
1989GTA's Avatar
Is this a isolated incident? How many others have there been?
Old 04-09-2007, 01:59 PM
mwill15's Avatar
The link worked this morning. Has the thread been deleted?
I had a spring break just as shown in the pictures that WERE in the link above. Comp agreed that it was a faulty spring and replaced the set. Didn't help out my destroyed block, piston, and head though.
Old 04-09-2007, 03:30 PM
AZ2ENVY's Avatar
The thread was deleted and this one was posted in its place ....
http://web.camaross.com/forums/showthread.php?t=513691
Old 04-09-2007, 03:52 PM
quick346's Avatar
I ran the 918's for 10k mile's with .587/.589 lift and did not follow the first heat cycle procedure and had zero probs. spun her to 6800 a thousand time's.
but on a side note i was always worried about them.
dual afr's now.on the afr heads. i would say worries over but i know what that will get me.
Old 04-09-2007, 03:57 PM
quick346's Avatar
also i heard this is a old prob . they had a batch a while ago. even the cam section here talks about it. i would not be too concerned. at a last resort call comps tech line and ask them.
But just be ready for the guy to be a ***. i called them about the comp r lifters and the guy was a total *****. saying it was the consumers fault.
I mean a .002-.004 preload on a hyd lifter. give me a break. a standard peice of paper is right around .003.
just a heads up if you call comp. you may hang up pissed off.
Old 04-09-2007, 05:11 PM
vettenuts's Avatar
There was a rash of broken 918's here on LS1Tech over the last few months, I think the original story is the right one and now they are in CYA mode.
