Just installed my suspension mods.
Just installed my suspension mods and hearing some weird noises!
So this weekend I decided was the weekend to put all my suspension mods on (though in St. Louis it decided to snow). I bought some koni S/A's, strano lowering springs, and a pan hard rod. I put everything thing on without a problem with one exception. We forgot to put a bushing under the body in the rear so the spring compressed up against body for only bump and then we realized what happened. I have one question and that is that the front struts or springs are making a little noise whenever they go over a bump. I was just wondering if they are making a little bit of noise because they haven't had any load on and they need some time to adjust or is there something wrong? Oh yeah and I want to thank SAM STRANO for all his help! He is the man!
LS1TECH Sponsor
I can't help because I can't hear the noise.....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Did you re-torque the Strut tower bolts once the car was on the ground with loaded suspension? When I did the shocks on my car I had to tighten it down more since it still had a tad of travel room and would bump some up front.
