LS1 diff same as LT1 diff...ABS still work?
Would a diff in a 00 LS1 Z28 be a direct swap into a 95 LT1 Formula? I was worried about the differences in the ABS and I want to keep the ABS working.
Thks
JD
Thks
JD
Internet Mechanic
Do you have traction control, TCS?? I am not sure if 95's had it, if it did the abs rings are at the end of the axles, and 3 channel abs (no TCS), the ring is in the diff and the sensor is ontop of the pumpkin, find this out 1st. I have a PRISTINE 4 channel for sale, see my link.
