which springs with the cc305 cam??
These are the springs I picked out for my cc503 setup:
Crane Cams 10308-1
http://store.summitracing.com/partde...5&autoview=sku
Summit seems to be the cheapest place that I was able to find them from.
Crane Cams 10308-1
Originally Posted by getdrugtoday
are these on your car yet?? work good? i see the heads need to be machined for those springs. no big deal on that part though.
heres my question.. cranes springs are 1.46 diameter and stocks are around the 1.27 range.. thats a big difference.. i mic' the pad the spring sits on and 1.46 will actually sit alittle off the pad.. if you guys are running this than tell me how your doing it without cutting the pads to fit?? not a big deal for me to mill these but just wondering.
it came with new pads to sit on..so no machining was necessary..i think the iron heads may need machining or something.if im not mistaken thats what the machine shop told me..aluminum heads were ok or something..dont quote me or hit me with any comments cause that came from the machine shop
I have LT4 springs with the CC305 and haven't had any problems.Mine came from Scoggin-Dickey Parts Center,they cost $32.95 A couple of years ago .I have run them to 6500 rpm with no problems (If my stock tach is correct?)
