What is wrong with my car?
Old 04-09-2007, 06:21 PM
That_guy's Avatar
Default What is wrong with my car?
I have a 1994 trans am and it gets to 210 to quickly , when i stop and turn it off after a 30 min drive you can hear the engine boiling i hate that sound , the car works and everything but what can i do to solve this problem o by the way when i let down my lights the passenger side makes this really loud noise when they go down , but i noticed when the manual switch under the hood spins when i let them down.
Old 04-09-2007, 07:09 PM
FlamingChicken's Avatar
the noise from the headlight means the gear is stripped inside the motor. search on the solution but you basically turn the gear so you use the half that is not stripped or buy a new gear. as far as boiling check to make sure your fans are working and there are no air pockets in your cooling system.
Old 04-09-2007, 07:54 PM
That_guy's Avatar
ok any more suggestions and i will get the fans checked on and ah where do you think the air would be coming from in the system
Quick Reply: What is wrong with my car?
