PCV & AFR?
PCV & AFR?
Hi guys;
My latest endeaver with my STS turbo is to find out why my AFR is going from 9.8 at 35deg to 11.8 at 76deg at initial PE mode.
After I learned the limitations of the PCV setup and not really wanting to run a 3/8 hose all the way to the back of the car I put in two check valves up front with a catch can. Closed loop, normal, and open loop venting. Now, I've disconnected this so its blocked off and just venting to atmosphere which will work, but's a little stinky. I haven't tried it yet, but, do you think this is it?
Thanks!
Thanks!
