koni adjustables vs. bilstein revalves
for koni's; if you ever change springs you can adjust the shocks per the new set. when you get new tires if they have a stiffer sidewall you can adjust the shocks
for bilsteins; they're cheaper by about 250...but could be too rough for what you want when you change tires..or get bigger rims
If you can afford the Koni SA's then get them. Sam first started revalving the Bilsteins to comply with certain racing class restrictions and got very good at it. It is cheaper, but you can't change them. With the Koni's you can adjust them to your whim. Some tires are soft, some firm, you can adjust them to give you the ride you want. They are the better choice if you have the funds.
Originally Posted by JasonWW
Ajustable is always an advantage so I assume everyone would prefer them. It really comes down to money.
Originally Posted by kodiak
If I lowered my car with strano springs what advantages are their with
koni adjustables vs. bilstein revalves ?
My car is used only for nice day pleasure cruises !
Thanks
Thanks
What springs are you using? If you think you might change springs a lot, then get the koni's. If you just want to do the springs once, get some revalves. FWIW, I use the same Koni setting on my stock springs as I do aftermarket springs
LS1TECH Sponsor
Originally Posted by gollum
Only rebound is adjustable with the KONI SA shocks. Correct?
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Originally Posted by MeentSS02
He asked what was adjustable on the Koni SA Shocks. I know full well they offer a DA shock, but he wasn't asking about that.
So Eat ****!!!!!!
So Eat ****!!!!!!
WTF is your brob anyway?? Having a bad day girl?
LS1TECH Sponsor
I think his point is that you maybe should have noticed that before muddying the waters. As a side note, this is the bad part of forums. Folks only take bits and pieces away from posts and that can be a bad thing.
__________________
Kleeborp the Moderator™
The forums are getting worse about this kinda stuff...that's what my problem is, "brah".
That was exactly my point...Kage posted what I quoted, then retracted it to post what ended up going below mine. He was in a big hurry to point out my mistake and realized he had made one.
