Sponsor Group Purchases - Livernois Motorsports' Spring Blowout Sale!! **
Chad@LivernoisMotors
04-10-2007, 10:23 AM
We all know its starting to get warmer and its time to bring the toys back out. :devil: Which is why starting today until April 21st, we will be holding a special on many different manufacturers products.
Please PM, eMail or Call me for PRICE QUOTES!
We are running a sale on ALL Professional Products stuff, however here is some of the featured items you guys may be interested in.
http://i3.photobucket.com/albums/y71/losiguy/Professionalproducts.jpg
LS1/LS2 Typhoon Intake MAnifold
http://i3.photobucket.com/albums/y71/losiguy/ProfessionalProductsTyphoonLSMan-1.jpg
This manifold is the result of over one year of development and testing and has proven to provide significant increases in power. In direct comparison dyno tests against a factory LS6 intake manifold, the Typhoon produced 17.7 more horsepower* at 6,200 rpm. It also makes more power and torque at low and mid-range engine speeds than other aftermarket manifolds. This design features a larger plenum volume, which makes the manifold suitable for larger displacement engines. The manifold has nitrous bosses positioned on the port runners. The LS1/LS6 version comes with either an 85 mm inlet or a 96mm inlet. Professional Products offers 80 and 85mm throttle bodies and 96 and 101mm throttle bodies are in development. The 96mm inlet version of this manifold can be used with either the stock 91mm LS2 throttle body or various aftermarket large bore throttle bodies. The manifold kit includes high volume fuel rails with stainless steel mounting brackets, stainless hardware, and a -6 AN stainless braided crossover hose. Additional fittings are also supplied that allows connection to the stock fuel inlet line.
Available in both 86 and 96MM. The 96MM will work with your stock LS2 Throttle body!
Professional Products Throttle Bodys
http://i3.photobucket.com/albums/y71/losiguy/PPLSxTBs.jpg
Professional Products offers this style throttle body in two sizes; 80mm and 85mm. The 80mm version is typically suitable for use on stock intakes. The 85mm size is for use on the Professional Products #52060/#52061 LS1 Typhoon Intake Manifold or other LS1 aftermarket intakes. These throttle bodies feature die cast aluminum construction and are O.E. quality units. Both models include an aluminum transition plate that bolts between the stock manifold and the throttle body. This transition plate smooths the flow of air when using the throttle body on a manifold that has an inlet opening smaller than the throttle body. These units are a direct bolt-in replacement for the stock throttle body. GREAT prices on these guy's!
Professional Products Fuel Rail Kits
http://i3.photobucket.com/albums/y71/losiguy/ls2intakefuelrail.jpg
10611 Complete Fuel Rail Kit for LS1-1997-'98
w/fuel return system
10612 Complete Fuel Rail Kit for LS1-1999-'04
10614 Complete Fuel Rail Kit for LS2-2005-'06
The Complete Kit includes all the parts from the Basic Kits plus a stainless braided -6 AN fuel crossover hose, additional fittings and an adjustable fuel pressure regulator in the 10611 kit.
Please PM me on these or any product you may need from Professional Products for pricing!
We are also holding a special on all Livernois Motorsports LSX Heads Stage 1,2,3,and 3R. Along with stage 1,2,2R, and stage 3 Camshafts.
http://i3.photobucket.com/albums/y71/losiguy/Livernoiis-1.jpghttp://i3.photobucket.com/albums/y71/losiguy/ls1cam-2.jpg
And what everone was waiting for, a special on Livernois Motorsports Stage 1,2, and 3 L92 Heads. Along with the matching camshafts!!
http://i3.photobucket.com/albums/y71/losiguy/L92cylinderheads.jpghttp://i3.photobucket.com/albums/y71/losiguy/l92cam.jpg
Last up we are running a special on all KOOKS products! As most of you know they make some top of the line stuff. Quality is unbeatable.
http://i3.photobucket.com/albums/y71/losiguy/kooks.jpg
We are offering discounts on anything the above vendors carry, but once agian please PM, eMail or Call me for pricing!
Thank You,
Chad @ Livernois Motorsports
cmaley@livernoismotorsports.com
313-561-5500 EXT 2124
ss1
04-10-2007, 01:20 PM
PM sent on some heads...
04-10-2007, 01:52 PM
PM returned. Thanks. :devil:
ROJO99
04-10-2007, 04:41 PM
Ditto...
formula17
04-10-2007, 05:29 PM
Pm Sent
myws6istheshiznit
04-10-2007, 10:03 PM
i need a set of fuel rails for a ls6 motor with crossover line fittings and mounying hardware. price please?
04-11-2007, 11:59 AM
All PM's returned. Thanks.
diablotruck
04-14-2007, 03:14 PM
pm sent thanks mario
SLP4CamaroSS
04-15-2007, 11:23 AM
pm sent thanks
1BADTALS1
04-16-2007, 03:12 PM
what price do you have for a fuel rail kit(everything needed to install with stock fuel inlet line) i have a 2000 TA with a ls6 intake mani. and do the rails come in black?
04-18-2007, 03:05 PM
Thanks for all the interest and please PM me to speed up response time! Thanks!
04-19-2007, 02:14 PM
New specials on head/cam if purchased at retail price
Special #1
Buy ANY Livernois LS6 or l92 head, stage 1, 2, 3, or 3r Along with a Livernois Stage 1, 2, 2r, or 3 Cam (ls6 OR l92) and get a $50 gift certificate good for future purchases (for pushrods, gaskets, wires, injectors, etc.)
Special #2
Buy ANY Livernois LS6 or l92 head, stage 1, 2, 3, or 3r, a Livernois Stage 1, 2, 2r, or 3 Cam (ls6 OR l92), and matching Cometic head gaskets and get a FREE set of ARP head bolts
Special #3
Buy ANY Livernois LS6 or l92 head, stage 1, 2, 3, or 3r Along with a Livernois Stage 1, 2, 2r, or 3 Cam (ls6 OR l92), and Cometic head Gaskets and get $160 off of a Livernois Dyno Tune
1BADTALS1
04-19-2007, 08:34 PM
04-20-2007, 01:19 PM
We all know its starting to get warmer and its time to bring the toys back out. Which is why starting today until April 21st, we will be holding a special on many different manufacturers products.
You have a PM.
Thanks for the orders so far everyone.
JEB99TA
04-22-2007, 06:50 AM
PM'd ya'.
a98ws6
04-22-2007, 06:49 PM
What are the cam specs on the stg 3?
88ls1blazer
04-22-2007, 08:02 PM
here are the cam specs for the l92 cams
http://www.livernoismotorsports.com/product.phtml?p=1568&large=2
here are the cam specs for the ls1/2/6 cams
http://www.livernoismotorsports.com/product.phtml?p=1477&large=2
04-23-2007, 01:48 PM
Due to the great response the sale has been extended to May 5th!
Thanks,
JDP
04-23-2007, 04:38 PM
hey chad, instead of getting a "stage cam" could you get a custom grind for me with the set of heads and gaskets, so i could get the discount on the tune.
it would be nice to get all my stuff from one place.
let me know next time i see you, so we can get my damn car going again
04-25-2007, 02:40 PM
TTT all PM's returned.
JoeyGC5
04-25-2007, 06:59 PM
Could you reply to my last pm or give a good time to call.
JDP
04-26-2007, 06:57 PM
the guys picking up the mopar tomorrow buddy, ill be ordering soon.
thanks chad
04-30-2007, 01:07 PM
Joey, my engine builder is working on that price and specs for you right now. I will have info by the end of today.
Thanks,
Chad @ LM
Gun5
03-19-2008, 03:05 AM
111111
88ls1blazer
03-19-2008, 06:45 PM
wow, bringing this back from the dead :) Check the sponsor group purchase area for a smokin deal on their stage 2 heads :D
