crankshaft question
crankshaft question
I'm sure that this isn't a new thought, but will the 6.0 truck crank fit the 5.7 block? Is it the same crank, but the 6.0 had a larger bore? Just looking for a stroker option for less than that of the $2k forged cranks..
Thanks in advance!
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks in advance!
Re: crankshaft question
You would need to grind rod journals from 2.100" stock to 2.00" small journal SBC size. You would have to have crank rehardened(nitrided) because its only around .010" deep. Not a bad idea though as long as a nice radius is maintained with grind work. Im not sure crank grinder could duplicate rolled fillet radius like factory uses.
