Forced Induction - Whose running HV oil pumps?
94blownz281
04-10-2007, 04:59 PM
i have a brand new HV melling sitting in the box for when ever i get my rebuild finished. just curious how much they are really needed? i heard aftermarket pumps need aftermarket pans as well? my max with my s-trim would be 10-12psi . street car only. thanks
ls1290
04-11-2007, 10:59 AM
I have the Melling LS1 pump installed in my 402 with the high pressure spring. The 402 is using a LQ4 block which I believe has slightly different oil passageways that the LS1/6. At idle I am seeing about 50 to 52 psi. Since I am still breaking in the motor, I have only taken it up to about 4500 rpms and the oil pressure was in the mid 60s. The reason I went with the high pressure spring is that I am going to run an oil cooler and the cooler and lines will drop the pressure a little bit.
Keith
94blownz281
04-11-2007, 11:02 AM
hmm alright cool :)
melling #10296 pump+blue spring=awesome volume and pressure for your set up. :) good luck.
NA$TY-TA
04-15-2007, 12:35 PM
Im running the melling oil pump and at 6K Plus ive pegged the gauge at 100+ psi.....
Aftermarket gauge also....
My idle warm is around 45-50 and 60-70 and 3-4K rpm's......
Kyle
94blownz281
04-15-2007, 01:29 PM
okay cool glad these pumps work and hold up then. :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
