Found something in my oil
Old 04-11-2007, 08:13 AM
onebadZ28's Avatar
Default Found something in my oil
ok i went to change my oil and as soon as i pulled the drain bolt out i noticed a lead colored material on the tip of the bolt. i wiped the bolt off and the material just smeared into a gray stain (the color of lead). The car has had regular oil changes every since new. I don't really run the car hard. about two months ago i put QTP headers on, and i changed out the spark plugs and put NGK TR55 in it i also put antiseize on the spark plug threads. now my question is could i have put to much antiseize on the threads? also i noticed that my car has a little bit of white smoke coming out of the exhaust now. The antiseize that i used was the color of lead. if the antiseize did make it's way into my engine do i need to worry about this or is it something that will work it's way out eventually through regular oil changes? also the engine runs fine, and i haven't heard any weird nosies of any kind. all thought and suggestions will be appreciated
Old 04-11-2007, 08:17 AM
crazylane's Avatar
I dont think that is Antiseize, if you put an excess amount on them they should have burned off, or crystalized on the spark plug. That would be my guess, Was is a metalic looking gue? Like did it have a sparkely look to it?
Lane
Old 04-11-2007, 09:21 AM
onebadZ28's Avatar
yeah it was metallic looking color, and when i pulled the drain bolt of the material was stuck to the tip kinda like lead sticks to a magnet then i wiped the tip of the bolt off using a paper towel and the material just smeared into a gray metallic color. is this somthing i need to worry about?
Old 04-11-2007, 10:12 AM
aNuBiS's Avatar
Thats because the tip of the plug IS a magnet. These are just tiny metal particles.
From what I gather this is normal, everyone has this.
onebadZ28's Avatar
bump for more info
Old 04-11-2007, 10:13 AM
PortPros1's Avatar
How many miles do you have on the motor? The antiseize is not your problem. Are sure your seeing white smoke, not blue?
If it's white your burning water, blue it's oil. I would change the oil and filter and put another 500 or 600 miles on it and then check your drain plug again.
Let me know what you see and we'll go from there.
Old 04-11-2007, 10:14 AM
Rhedalert's Avatar
that sounds like normal metal debris that's picked up by the magnetic plug. I'll see it on my LS1, the new 4.8 in my father's '07 Sierra, even in my 3400 V6. You've never seen this before during prior oil changes?
Old 04-11-2007, 10:15 AM
onebadZ28's Avatar
i have 66,000 on the motor. the smoke looks whiteish but it could be blue i'm not sure. i'm just worried to death about this
Old 04-11-2007, 10:25 AM
onebadZ28's Avatar
never not once this is the first time i've seen anything out of the ordinary
Old 04-11-2007, 10:39 AM
01Z28M6's Avatar
Forget the anti seize, you're seeing just what aNuBis said it is. If it is a small amount then stop worrying. As for the smokey exhaust, you are probably seeing normal moisture being expelled as steam that you didn't notice before because now you're worrying that the engine is failing.
I imagine you wiped the magnetic drain plug clean. Drive the car a few hundred miles and pull the plug again. If you see a good amount of the same stuff then investigate further but my guess is you wont' see anything appreciable. Tiny amounts of metal work their way to that magnet. I always have something on the plug every time I change oil on all six of my vehicles. Good luck.
Old 04-11-2007, 10:46 AM
onebadZ28's Avatar
thanks a ton guys
Old 04-11-2007, 01:33 PM
aNuBiS's Avatar
Exactly, better safe than sorry, unlike most people who let **** go til it falls apart.. ..so it was worth asking but I am pretty sure its all normal so I would drive it and have fun.
Old 04-11-2007, 02:30 PM
heavymetals's Avatar
You can worry if you find pieces of stuff on the drain plug.
I don't think anti-sieze is magnetic anyway.
Old 04-11-2007, 02:33 PM
c0ncEpT's Avatar
I always get a little bit of metallic color metal on my drain plug. 100% normal
Old 04-11-2007, 06:08 PM
onebadZ28's Avatar
good deal i'm going to drive it 500 or 600 miles and pull the plug again. if i see it anymore i believe i'll get a oil analysis done just to see what it is (curiousity). the reason i worry so much is because i just spent a ton of money in upgrades and i would hate to be saving up to fix my car before i get all the goodies on it. by the way i'm the second owner of this car. i bought it off of a 60 year old man who bought it brand new. when i purchased the vehicle it had 57K miles and completely bone stock. i feel like the guy never drove the car hard at all, but when i got ahold of it i drove it a little more aggressive. This is my thrid oil change. could it be stuff just wearing in the engine now that it's being drove a little harder? if so what could be wearing?
Old 04-11-2007, 07:55 PM
crazylane's Avatar
Well my quess is that it would not be anything aluminum wearing down, So it would or could be bearing's, lifters, Springs, anything that has carbon metal in it.
Lane
Old 04-29-2007, 09:21 PM
Joey7489's Avatar
i got a tiny metallic piece on my last oil change.. i also changed my friends oil (SS) he had a little bit of a metal piece in his as well..
Old 04-30-2007, 12:33 AM
Lurius's Avatar
When it smears like a metal paste on a paper towel its normal, wont worry until you find chunks of metal rofl.
-Lurius
Old 04-30-2007, 03:34 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You sure that it is not just normal oil debris on the drain plug and you are just experiencing some early stages of ring wear which is possibly causing blow by?
Old 04-30-2007, 12:45 PM
silverbandit0996's Avatar
yea its always on mine every time i change it. i dont even worry about it anymore.
