What's this dimple on the piston?
Next question - Should I remove the carbon from these pistons? What is a good method to keep the scraped off deposits from going places like down the cylinder wall and onto the top piston ring? Thanks....
Any type of pad or material that is softer than the aluminum and will not gouge, nick or mark the piston. Scotchbrite seem to work good. I use a similar pad with a dremel tool. Like was mentioned coat the cylinder walls with oil, i've found fogging oil works best as it's a little tackier than regular oil and catches the carbon better. Use a wet/dry vac sucking helps too. Put the piston your cleaning at TDC to clean. I also tape off the other bores and work on one at a time. After your done take the piston to BDC a few times wiping the bore with new oil and clean rags.
