Patriot Gold Valve Springs on a stock motor
Old 04-11-2007, 12:22 PM
Karpellarpy's Avatar
Default Patriot Gold Valve Springs on a stock motor
hey guys, I'm slowly getting into the fi game with my daily driver. the plan is to go with a procharger. I'm trying to do some of the preparations for boosting the car in "weekend sized" steps so I can keep the car up and running as much as possible. I was wondering if it's ok for me to install and drive around with the patriot Gold valve spring kit on my stock motor before the procharger install & tune. Also, I've been told that I need to upgrade my springs, but didn't know how to determine the spring pressures needed and stuff for my application.
Old 04-11-2007, 12:36 PM
camarols1's Avatar
I can't see the harm of running the Gold's on the stock cam.
If you could post up the intended power goals for the car maybe
some people with similar builds could advise what springs would be ideal.
Those are a popular spring for mild boosted applications.
Old 04-11-2007, 04:22 PM
being stock internals, I am planning on trying for hp in the low 500s or a while. from what I've read, much more than that, and the motor will be pretty short lived. With a d1sc i think it will take 6-7psi ... p1sc will probably take 7-9psi. This isn't first hand experience as I'm new to fi, but just what I have read. Feel free to correct me if I'm wrong.
Old 04-11-2007, 04:27 PM
i just don't know how different spring pressures effect a stock motor. I mean, I would think it would cost a few hp to open valves that have a higher spring pressure. And it would seem plausable that an unusually high spring pressure could cause cam lobes to be eaten or something.
Old 04-11-2007, 06:27 PM
MiaSSmaro98's Avatar
good question ,but just put a small cam in there to help out
Old 04-11-2007, 09:18 PM
gametech's Avatar
Absolutely DO NOT do bigger springs without pushrods. Other than that, I don't see a problem.
Old 04-11-2007, 09:51 PM
camarols1's Avatar
Better pushrods would be required with upgraded springs.
Considering the overlap of time in doing the upgrades in stages,
you might be better off taking a day or two off work so you have
the time to do both mods (cam, springs & pushrods) at once.
I know I hate having to take apart stuff over and over again!
That way when you go FI, you won't have to tear into the motor.
Just my $.02
Old 04-11-2007, 11:19 PM
yeah, I didn't mention it, but I was planning on doing pushrods, but honestly wasn't concidering a cam. The spring change is just a preventive measure to avoid valve float. I guess I could throw in TR's cheaTR or blower cam in there, but I wouldn't be getting a tune until the procharger install.
Old 04-12-2007, 05:02 AM
EPP
EPP's Avatar
The Patriot valvesprings won't hurt your camshaft anymore than they would an aggressive camshaft. We use them on a lot of our installs, and I would use them in your combination. http://www.exoticperformanceplus.com....html?item=651 Bob
Old 04-12-2007, 07:22 AM
Senior Member
Country Boy's Avatar
Youll be just fine. I would use them for any FI setup. I had them with my LPE GT2-3 cam.
Old 04-12-2007, 11:48 AM
Thanks guys, just the info I needed!
Old 04-12-2007, 11:26 PM
99Z28LS1's Avatar
goodluck and i hopeit works out for you. i had them installed along with the custom ground cam and rods too
Old 04-12-2007, 11:34 PM
RooRnZ28's Avatar
i'm running the patriots as well... so far so good!!
