differences in cables?
Anyone have any idea what the differences are between the F-Body battery cables ('98-02) and the full size pickup battery cables ('99-05) are?
I'm coming to a close on my swap, and the F-Body cables are too short, trying to stay somewhat stock, and I'm curious if:
* The truck motors ground in front of the starter like the F-body does (same location - in front of starter)?
* The starter connection for the truck uses the same size ring terminal?
*There are the same number of positive/negative wires coming off the cable end?
* Anyone know the length of both the ground and power cables for the truck?
sawzall wielding director
The truck + cable goes from the starter, around the front of the block by the oil pan, up the drivers side accy. brackets, to a power distribution box on the accy. bracket, and then has ~24 inches coming out of the dist. block to go to the battery.
The - cable just attaches to the block, I think I attached mine to a bolt by the water pump.
I *Think* that my bat + cable had the large diameter battery cable and a second large wire coming off of it to feed the underhood fusebox, but I can`t remember for sure. I cut the end of the cable off and spliced it because I needed more length. I may have some pictures of it on my f-quick account, I could snap some of the engine compartment, but it probably wouldn`t be until friday.
I'm not working on the truck till Sunday, and I'll have access from the hotel in Savannah I'm staying at, so I could potentially stop by a dealership and pick one up if necessary. It doesn't look like I'm going to get my cable ends by Friday as expected, but ... pleasant surprises never cease to amaze, so ...
Here's keeping my fingers crossed that we get to have a first fire-up on Sunday
any pics you can contribute, or any info anyone has on the truck cables is appreciated.
