Can anyone help me out with my compression ratio?
My heads have been milled .025 . I will be running the Lunati 382 rotating ***. with pistons that are -8cc. The Lunati kit is supposed to give a CR of about 10.7 to 1 with stock heads. How can I figure out what my CR will be with my heads milled .025?
Re: Can anyone help me out with my compression ratio?
A .025 mill should raise your compression ration about 4 tenths of a point. If you want to know exactly, have your combustion chambers CC'd.
This is going to be true whether you have a stroker motor or a stock displacement motor. Milling the head raises the compression ratio because the combustion chambers are smaller.
