Vid...my 10.99 run
tham ur car runs great what kind off cam do u have? do u have ur stock drive shaft and rear end cause it look like u left pretty hard any suspension work. ur car ****** moves and nice good job
its a 245/250 .611/.615 110+1 just put it in 2 weeks ago.
i have the dynamic motorsports sus. lowered but i did put stock springs in the rear last week to help the launch.
stock drive shaft, stock GTO trans, Moser 12 bolt w/ 4.10s
-brandon
-brandon
Originally Posted by SLPSS99
Might be a stupid question but why did you put in a GTO Trans? Are they not the same as an F-Body?
Hey bad *** run. Idle sounds pretty good for the size cam to cu. in. w/no heads or maybe its the video sound or some pretty bad *** tuning. Props on the good run. Oh by the way whats your lobe sep @.
Is that popping or riding the clutch and what clutch is that? I hold my rpm at about 4000 and about a second before I launch, I floor it and pop the Textralia. Seems to work pretty good...not too consistent but it's worked since I tried it. Your launch sounded similar.
Originally Posted by Sudz
damn i never seen a blipping rev launch that good, whats your strat?
Congrats on the run, that is awesome.
im using a Lngenfelter clutch. race weight is 3260 w/ me in the car.
yeah the GTO trans has lmost the sam exact gearing as the z06, only thing hats different is the 5th an 6th gear,but who cares about that.
MT DRs set at 18.5 psi
thanks everyone!!
brandon
thanks everyone!!
brandon
