4.00" Bore sleeves??? Builders please respond.
Do the Darton sleeves come in 4.00" bore? I'd like to do a 4.00 x 4.00 motor with an Al block. I'm quite aware that the iron block comes with a 4.00" bore, but I'd like to do FI with this block and would rather not put any additional weight on the front of the car.
And...if I were to do that, would the price be the same as the 4.125" sleeve?
Thanks.
Thanks.
Re: 4.00" Bore sleeves??? Builders please respond.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FASST:
<strong>Do the Darton sleeves come in 4.00" bore? I'd like to do a 4.00 x 4.00 motor with an Al block. I'm quite aware that the iron block comes with a 4.00" bore, but I'd like to do FI with this block and would rather not put any additional weight on the front of the car.
Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hi Fasst! I have done re-sleeved bores from 3.960 and up to 4.100. I can finish the bore size where ever you want it. Our re-sleeved block sells for $2350 (+core) fully machined and ready to assemble.
Dave
www.agostino-racing.com
Dave
Thanks everyone for the quick responses. I'm looking to do a TTi setup damn near identical to the Incon set. Normal street driving at 5-6psi with the engine built to handle ~12psi...maybe more <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> for track work. It sounds like the sleeves are available, my only other question would be concerning the thickness. Would a sleeve with an intended finished diameter of 4" be any thicker than the 4.125". For my app, would it even matter?
<strong>Thanks everyone for the quick responses. I'm looking to do a TTi setup damn near identical to the Incon set. Normal street driving at 5-6psi with the engine built to handle ~12psi...maybe more <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> for track work. It sounds like the sleeves are available, my only other question would be concerning the thickness. Would a sleeve with an intended finished diameter of 4" be any thicker than the 4.125". For my app, would it even matter?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We have tested over 900RWHP with our 4.100 sleeves. At 4.00" it would be even stronger!
Nate, how much boost/hp have you tested with?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SLED28:
<strong>We have tested over 900RWHP with our 4.100 sleeves. At 4.00" it would be even stronger!
Nate, how much boost/hp have you tested with?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I guess 900 would be enough <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Closed ex-Sponsor Account
The Darton sleeves we order are 4.050" bore when they arrive. I would suggest checking Darton's website, or giving them a call to see if the LS1 sleeve is available in a smaller bore size. Pricing should be close to the same if they offer that size.
How much power are you planning to make? If you plan to stay N/A, and make less than 500hp, the factory sleeve can handle a .010" oversize, but that won't leave you any room for repairs later, or if you plan on running high boost, that would not be the best way to go.
Ed
<small>[ December 13, 2002, 12:53 PM: Message edited by: Ed Potter @ LPE ]</small>
Ed
