Urgent head install question
Re: Urgent head install question
You're fine, totally normal for the situation you're describing however I'd pull the plugs out turn the motor at least 760* to make sure there is no binding or anything hitting. Easier to do it now <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
LSxGuy widda 9sec Mustang
Yes, thats air going past the piston ring gaps. With the spark plugs in you are compressing the air in the cylinders and its escaping past the rings.
