Thoughts on ASA or GM HOT CAM
Old 04-11-2007, 10:18 PM
SSsuperdave's Avatar
Default Thoughts on ASA or GM HOT CAM
I've read good things about the ASA cam, good low to mid-range torque, flat curve, decent h.p. but how does a GM HOT CAM compare. I'm looking for a little more h.p., not a lot, for my daily driver. What kind of gas milage should I expect? What about tuning issues, and upgrades along with a cam swap, injectors, lifters, push-rods?
Old 04-11-2007, 10:45 PM
JBIRD02's Avatar
I can only speak for the ASA cam since I've never had the hot cam. I really like the ASA so far. Its a good all around cam (at least in my opinion). Its good on the bottom end, great in the midrange, and pulls hard to 6400rpm. You can check the #'s in my sig. As far as upgrades go, you dont need lifters or injectors (unless theres something wrong with the ones you got). I upgraded to LS6 springs (good to .580), 7.425 pushrods (from Thunder Racing), LS2 timing chain, and all the necessary gaskets.
Old 04-11-2007, 11:10 PM
35thUCF's Avatar
ASA is the shizznit, it sounds like an old school big block, if you are stuck between the 2, go ASA.
Old 04-12-2007, 01:27 AM
GR33N GoblinM6's Avatar
here is the thread about the ASA cam
ASA Cam thread
Old 04-12-2007, 01:29 AM
d james's Avatar
I've been thinking about one of these cams as well. I would think the hotcam would be easier to drie, and maybe to tune. I read some article that a GM guy working on the cams said the ASA didn't make much more horsepower I think 5-10 if you didn't open up the exhaust all the way. So if its a street driven vehicle, it might not be worth having the bigger cam as a daily driver. I'm sure these guys can let us know if there is any truth in that, I for one would rather go ASA
Old 04-12-2007, 05:07 AM
kevins2000LS1's Avatar
ASA ALL THE WAY, just got mine in yesterday and damn that thing sounds awesome
Old 04-12-2007, 12:15 PM
L$1W$6's Avatar
+1 for the ASA!!
Old 04-12-2007, 12:37 PM
how come no one sells the hot cam by itself? they make you buy the damn kit, i dont need the kit, i need the cam only....
Old 04-12-2007, 01:25 PM
Redlinez's Avatar
JBird02, I want to hear some track times......
Old 04-12-2007, 01:46 PM
jmm98LS1's Avatar
Absolutely LOVE mine, had it for two years now. People stare every time I take the car out. As soon as the damn weather cooperates so our track can open, I'll have some e.t.'s to post.
Old 04-12-2007, 02:01 PM
L$1W$6's Avatar
Just installed mine with some LS6 heads and some other goodies. Getting it tuned saturday. I'll let yall know what it put down.
Old 04-12-2007, 02:06 PM
Redlinez's Avatar
That's what I'm talking about. Looking forward to your numbers. If it makes so much bottom end, it should put down awesome track times as these cars suck down low. Most of the cams pull hard from midrange up. That should also make an awesome street cam, but it would seem odd that it's marketed as a roadracing cam. That would mean it sucks down low.
Old 04-12-2007, 02:14 PM
well not necessarily..
big difference in road racing and circle track racing.
Circle track you are just sitting, most of the time in the same gear...
road racing you are mostly in 3-4 sometimes 2.. so you need the low end to get you out of corners...
Old 04-12-2007, 02:36 PM
SlowazzVette2's Avatar
Where can you buy the ASA cam from?
Old 04-12-2007, 02:40 PM
LS1W66's Avatar
I guess it all depends on what you consider is your low end
I wouldn't expect this cam to do much more over stock below 2500 rpm.
But obviously if geared correctly you can keep it in it's best power band (M6 4.10's) I have really liked this cam for awhile seems to me to be the best of both worlds aggressive sounding yet easy on valvesprings.
Old 04-12-2007, 02:43 PM
Scoggin Dickey.. or GMpartsdirect.. or Pace.. or Summit..
Old 04-12-2007, 02:47 PM
Cop Car's Avatar
IMO. why buy a cam for performance or quality of idle that is limited by a sanctioning body.. there are better cams out there than the ASA.
however, the hotcam i think is a good buy if you want to have a little extra power and a nice sound. cant beat it for the price IMO.
Old 04-12-2007, 02:49 PM
L$1W$6's Avatar
my goal is to make it a lil past 400 rwhp if they tune it right. It makes awesome tq. in all gears, always in the powerband! dont have to wait to be high in the rpms to start feeling the pull of this cam.
Old 04-12-2007, 02:51 PM
L$1W$6's Avatar
Another good thing about it you can use some LS6 springs with it and you'll be ok! I was happy with that because I was on a tight budget.
Old 04-12-2007, 02:53 PM
Nevermind I found it. Thanks.
Quick Reply: Thoughts on ASA or GM HOT CAM
