Driftfun Nissan 200sx with 04 GTO engine installed (pics)
Hi, I can write more info about my project later, the only thing ive got left to put on is the drive shaft, which im getting today. Then ill take it for a spin
http://bilder.driftfun.com/hersker-s13-ls1?page=1 <- 9 pages with pictures there.
I cut the nissans original crossmember, welded to 0.8 mm steel plates in as you can see, and a square tube underneath to get it at little lower. I had to lower it because i made it wrong the first time
I test drove the car for the first time today. Awesome!
Originally Posted by Gen3Benz
No more 300e?
This car is more suited to drifting anyways.
Originally Posted by tirefryin_s10
i think its a bad *** project etc but im just not a fan of the big bodykits ,keep up the good work though
why? its not going to help the car drift.... maybe for drifting someone should take the very clean simple approach?? just my 2 cents
Great job! I may do something similar after seeing how yours turned out. That is if you dont mind.
The clutchpump from the gto mounts nicely to the firewall btw, and the nissan servo pressure hose bolts right onto the GTO servopump.
looks good. as a previous nissan 240sx owner, and a current GTO owner, seeing this gave me a look into both my past and present. if this car ever gets totaled, im doing a swap like this.
X2 on the body kit not looking right. i would have went through the junk yard looking for something else. or check ebay. plus it doesnt look like it has good fitment from the pics and is that screws holding it to the frame?
I have a question for ya. What do you mean by the clutch pump? Is that the same as the master cyl.? If so you have any pics of that?
Josh
Originally Posted by ranger2339
Swap looks good!
Josh
Josh
This is the only picture ive got. but it is the oriignal gto master syl and it works ok..
I had to cut, angle and weld the header a bit to get som clearance to the frame on the right side.
OH NO not the wing lol
The wing is ugly as hell, but is needed to lift the smoke and keep it behind youre car while you drift.
Very nice work. Is the LS1 still stock? Don't listen to the style police, in my opinion vehicle appearance is of very small importance. Did you drift the car previously? Any major dynamic difficulties with the slight weight increase on the nose?
