Swapping motors
Swapping motors
I recently had some engine problems and im in process of taking out my motor. I was wondering though, i was considering swapping to a ls6, and need to know if it would be cool to use the flywheel and balancer off of my motor now, or would i have to buy a new one(ie. is it internaly or ext. balanced). thanks
Re: Swapping motors
Both the LS1 and LS6 are internally balanced, so you could reuse the flywheel and ballancer. Any new engine will come with a ballancer on it. You do realize that you can basically make your ls1 int a LS6 if you want? An ls6 is basically an upgraded LS1. You could add a cam and put on ls6 heads & intake and have essentially the same thing. For allot less work and money
