scavenge pump for turbo...return to pan?
I have read a couple times on here that people tap the pans and return the oil drain from the pump there. What is the benefit in doing that, other then it keeps more oil in the pan rather then in the top of the motor? I know sts uses the valve covers because they are easy to get to, but Ive got the motor out of the car and can put a fitting in the pan no problem.
well your not pumping all that extra hot oil into the head... that a good enough benifit for you?
Im going to a us e a pump and bring it into the valve cover for now.. when i pull the motor i will do a gravity to the pan... but cant do that in car soo...
pan is always the "best" if you can..
I went to the pan with mine, but I'll be the first to say I had to do it twice. The first time, the threads stripped out and I had a major oil leak, and I mean major!!!! Luckily caught it quick before I lost all my oil and then went back and did it the right way. Weld the fitting in and you'll be alot happier and you'll have that piece of mind that you don't have to worry about losing your investment due to loss of oil pressure.
